Gas in the oil? What causes this? - Page 2 - JeepForum.com
post #16 of 18 Old 04-21-2013, 05:40 PM
jblue1555
1979 CJ7
Be very careful as long as you have gasoline vapor you have a bomb. Do not cause an arch to ignite them. I was a witness to this and it is not something you want to be close to. Open the engine and let it breath as long as possible to let the gas evaporate.
jblue1555 is offline
post #17 of 18 Old 04-21-2013, 08:52 PM Thread Starter
CJ7KAHUNA
Well it looks like the fuel pump fixed his problem. He changed out the pump and changed the oil - took it out for a drive and it held oil pressure. He took it out for second test run and still good to go. The gas odor is barely present and is probably residual. Thanks to everyone that chipped in.
He still needs to address the air/fuel mixture issue. He will tackle that when he gets some time off. On that note - I know the MC2100 was a massive upgrade for my 85 CJ. Can he do the MC2100 ugrade if he's running a one barrel carb? Would he have to change out the intake manifold to do it? Would it be worth it? Is there known upgrade for the one barrel carb on that motor that is similar to the improvement the MC2100 is over the BBD?
CJ7KAHUNA is offline
post #18 of 18 Old 04-22-2013, 01:08 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I think any new carb is upgrade no matter if its another YF or a 2 bbl Weber with a 2 to 1 adapter.
I bet you would not notice any difference if they were both new.
Anyway, the only options would be a weber or a new YF. You could get a YF off a Ford 300. Those were big as far as 1 barrels go.
If you go Weber, buy the air cleaner adapter as well and don't use the anemic air cleaner that comes with it.
John Strenk is offline
