gas line info - JeepForum.com
post #1 of 7 Old 02-11-2002, 05:46 PM Thread Starter
2cjs
2cjs's Avatar
Angry gas line info
I installed an aluminum gas line on my jeep i purchased from summit.I have a 304 with headers and im worried about heat.Will i have a problem with heat even if i install the exhaust as far away as possible?
83 cj-7 258c.i., 727auto, d300, d44 front, d60 rear
92'yj 4.3(roller) tbi chevy,700r4 ,soa, 35-12.50-15 maxxis bighorns
89'yj wife's jeep 4.2l stock ,2"bl ,31-10.50-15 bfg mud terrains
work smarter not harder
2cjs is offline
post #2 of 7 Old 02-11-2002, 09:48 PM
Mugzilla Pavelko
Post
What is the summit part #?
How was it shipped, in a roll, or pre-bent?
Sorry, no data on whether or not you'll have heat problems. My guess is no. Heat is passed through air poorly.
Mugzilla!
RESTARTING a resto that BEGAN in 1985!
1975 CJ-5, 4WD fiberglass tub, 258,... TONS of extra parts!!!
Mugzilla Pavelko is offline
post #3 of 7 Old 02-12-2002, 07:03 AM Thread Starter
2cjs
2cjs's Avatar
Cool
part# 3131. It came in a roll not pre bent
2cjs is offline
post #4 of 7 Old 02-12-2002, 07:41 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
Wait and see is one way to tell, but being winter, you never know.
You could also do what I did. From the firewalk forward I covered my fuel lines with heater hose. This insulates quite a bit and is a nice, cushy cover for the lines for when a rock jumps up off the trail and tries to play "lets screw with Mike's Jeep."
Since mine are orange, it does not look cool, but it seems to work very well on my set up, but I have no headers and am only running a 258 w/ FI.
You could also wrap the headers, but I have not seen this done in a while.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #5 of 7 Old 02-13-2002, 11:25 AM
coopcj7
Post
I was running a 304 with the aluminum pipe from summit. 3/8 i believe. There will not be a problem with heat transfer as long as they are not touching or within 1/2" of the headers. Mine ran great.
Brian Cooper
1977 CJ7
Glass body
304 bored over .030
Chevy 350 coming soon (i hope)
2in lift
31" Cooper HT's
custom 2 wheel drive (temporary)
coopcj7 is offline
post #6 of 7 Old 02-16-2002, 07:37 PM
junger
Post
Ummm... been wondering about gas lines... is aluminum a better choice than stainless? I'm going to install some new lines in about a month on my 86 CJ7. I was tending toward aluminum also... what made you decide on it rather than stainless?
Thanks.
-Josh
junger is offline
post #7 of 7 Old 02-16-2002, 08:10 PM Thread Starter
2cjs
2cjs's Avatar
Arrow
Junger i went with aluminum for the only reason it was cheaper.stainless pre-bent lines will run about 90 bucks.I bought my line from summit in a coil.It was easy to work with,u can bend it with your hands and u dont need a bender.Summit part #3131 is the 3/8 aluminum line, I believe the lengh was 20 feet,I had alot left over. KENNY
2cjs is offline
Which line is transmission line feed and return on radiator? sweet76 Jeep CJ Forum 4 01-01-2010 08:45 AM
CivilianJeep.Info Site Has It's First Info Page Up! JeepHammer Jeep CJ Forum 10 09-30-2008 02:28 PM
brake line for fuel line USMCredneck Jeep CJ Forum 4 04-13-2008 09:37 PM
wandering form line to line jksull Jeep CJ Forum 3 01-27-2008 08:55 AM
Dumb Brake Line and Fuel Line Question GroundUpCJ7 Jeep CJ Forum 3 04-02-2007 06:01 PM
