Gas leak - JeepForum.com
post #1 of 5 Old 06-25-2003, 02:15 PM Thread Starter
390fastback
390fastback's Avatar
Gas leak
My neighbor told me I have a gas leak on the weekend. Today, coming out of the MACS I saw evedence of fuel on the skid plate. Some one please tell me that the tanks on these things isn't another common place for rust to accumulate and put my mind at ease untill I get home. By the way its an 86 CJ7.
Thanks
2000 Cherokee
68 Mustang Fastback (in progress)
71 Mach 1
68 Wildcat (also in progress)
68 International 1200 4x4
78 F150 4x4 400 4spd
390fastback is offline
post #2 of 5 Old 06-25-2003, 02:48 PM
fuzz401
1978 CJ7
i had a leak once on my gas tank the side strap wore through the side of the tank I put a screw in the hole and soldered it in never had another leak
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 5 Old 06-26-2003, 10:24 PM
Lightningdon
Lightningdon's Avatar
Just replaced the tank in my '75. Rusted out near the rear lower left corner. The muffler shop found it when his shop flamed up while welding my exhaust! LOL
'97 TJ
'75 CJ5 304cid, t18 tranny w/granny low, model 20 T Case, DANA 44 rear, 30 front, 4" suspension lift, 33" tires, in need of more work!
"The only thing necessary for the triumph of evil, is for good men to do nothing." (Edmund Burke)
Lightningdon is offline
post #4 of 5 Old 06-27-2003, 03:16 AM
Sandman74
First mod on both of my Jeeps has been a plastic tank. Both of the metal ones showed signs of rust. At least with plastic you know there is no rust fouling you fuel supply.
Youth and talent is no replacement for age and treachery.
Sandman74 is offline
post #5 of 5 Old 06-27-2003, 12:10 PM
dana60cj
dana60cj's Avatar
Yup platic, or polyethelyne, gas taks are the way to go. I'm on my third and final tank thanks to them. I've had it for 3 years now and everything is still good. www.4wd.com sells them.
'84 CJ-7, 6" lift, 33" BFG's, I6, .030 Over, Comp Cam, 400cfm Weber, K&N, T-18, 4 Core, Snorkel, D60 Detroit, Custom CV Driveshaft, 1350 U-Joints, D30 True Trac, Alloy shafts, S.R.S. w/ buggy springs, Custom Folding Shackles and Spring Hinges, Custum Tire Rack, Designed On Board Air, Optima's. Sneaky Jeep Owner #3.
dana60cj is offline
AMC 20 Leak, Need some help DT5150 Jeep CJ Forum 12 08-15-2008 06:02 PM
Another LEAK.... JeromyCJ7 Jeep CJ Forum 8 02-16-2007 09:36 AM
Bad Oil Leak Jeepman065 Jeep CJ Forum 10 09-22-2005 10:33 PM
Vacuum Leak/Gas Leak ravinhuxley Jeep CJ Forum 2 03-09-2005 09:18 AM
O-o-o-oil leak. djfuzzy Jeep CJ Forum 2 06-24-2004 09:23 PM
