#1 | |
Gas guage/water temp guage
I have a 1983 CJ5 and both my gas guage and water temp guage dont work, is there a fuse that is for both of these that could've gone out? I need to fix this soon so any help is greatly appreciated
#2 |
check the instrument cluster fuse first if not blown then you have a hot wire (red) coming into the back of the fuel gauge check it for fire as it feeds power to the fuel gauge and the temp gauge, if you have power thru the wire then make sure the instrument cluster is grounded, if you have both then the gauges are both bad
there are some very good articles on here as to gauge repairs |
#3 | |
Running On Empty...
But most of the time, it's the voltage regulator built into the fuel gauge that has gone out... Yes, I didn't misspeak, there is a voltage regulator built into the fuel gauge, and it knocks back the voltage for the guages to work with... There is a user named John Strenk here, and he has a WONDERFUL page or two on how to diagnose, repair, replace tune and work with these gauges. If I were you, I'd look him up and ask him directly for links to his pages! It's REALLY GOOD STUFF, probably the best write up and pictures you can find now on the trouble prone Jeep cluster gauges...
REMEMBER, 'Free' internet information is worth EXACTLY what you paid for it! LINK:Dual Battery Diagrams & Explanations. LINK:Winch, Welding, 'Lend Power' Project, LINK:Water Proofing Ignition, Hubs, Ect., LINK:BSERK's Winch Plate, LINK:AMC V-8 Front Cover Recondition, LINK:How An Ignition Works, LINK:Ignition Swaps '77 Older Jeeps, LINK:'78-'90 Jeep Ignition Upgrades, |
#4 |
WTF is that?
Here ya go - It's defintely in my favorites
http://users.adelphia.net/~john.strenk/Gauge%20web%20page/basic_troubleshooting_for_cj_gau.htm#Fuses
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift. AMC 20 Write Up In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles Coming Soon - CV Shafts, Welded Tubes, trusses |
#5 |
Thanks guys!!!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
