gas gage reading reverse? - JeepForum.com
post #1 of 9 Old 04-05-2013, 01:10 PM Thread Starter
jodowii2
1980 CJ7
when i got my 80 cj the gas gage didnt work so i diagnosed it to the factory gage being defective but since the od still worked i got an aftermarket gage installed and it works but it reads backwards as in E being full and F being empty? anyone ever had a problem like this?
jodowii2 is offline
post #2 of 9 Old 04-05-2013, 01:15 PM
gmakra
Did you re install the gas tank upside down? Seriously try reversing the two wires on the top.
gmakra is offline
post #3 of 9 Old 04-05-2013, 01:28 PM Thread Starter
jodowii2
1980 CJ7
on the back of the gage there is a positive and a ground and a source have all hooked up correctly i even tried changing the positive and ground no change
at the sender there is a clip for a ground and also the little threaded post for the source for the back of the gage what wires are u talking about?
jodowii2 is offline
post #4 of 9 Old 04-05-2013, 05:47 PM
John Strenk
John Strenk's Avatar
1976 CJ5
which gauges did you buy?
John Strenk is offline
post #5 of 9 Old 04-05-2013, 05:50 PM
raptorman
howdy; leave it alone if it works...Say, I just joined up today and need help
trying to fix l999 jeep cherokee sport radiator spout that is broken off...
How do I fix it?
raptorman...
raptorman is offline
post #6 of 9 Old 04-05-2013, 05:59 PM Thread Starter
jodowii2
1980 CJ7
just a cheapy from our autoparts store
jodowii2 is offline
post #7 of 9 Old 04-05-2013, 06:27 PM
lucdog
lucdog's Avatar
1980 CJ5
That would be the problem. You need for a 76 to 86 Jeep CJ.
You probably got a ford or Chevy gauge.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 9 Old 04-06-2013, 12:12 AM Thread Starter
jodowii2
1980 CJ7
ohh gotcha i think im just gonna leave it since it works it just reversed
just thought this was all kind of weard
jodowii2 is offline
post #9 of 9 Old 04-06-2013, 06:20 AM
davbytrace
1979 CJ7
Just had this happen when I replaced my stock gauge with a VDO gauge. It is not a problem. The gauge is just wired in reverse from the stock setup, but it will read accurately. There is no change in wiring that you can do to remedy it. The fix: Whenever the sender finally goes out, just replace it with an early YJ sender, and it will read normally.
Dave
davbytrace is offline
