Gas in the Crankcase - JeepForum.com
post #1 of 8 Old 11-04-2013, 09:37 AM Thread Starter
CW81Scrambler
1981 CJ8
I checked the oil in my CJ8 yesterday and the level was high and smelled like gas. It's carbureted and won't start without putting some gas directly into the carb. Is there a way that gas is draining down into the crankcase?
CW81Scrambler is offline
post #2 of 8 Old 11-04-2013, 09:45 AM
only in a jeep cj
Yep, bad diaphram on your fuel pump. Don't run it till your change oil and pump.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 8 Old 11-04-2013, 09:46 AM
seabass1858
1983 CJ7
x2. you are more than likely pumping fuel into your crankcase that explains the loss of prime on initial starts meaning you have to put fuel in your carb. Try replacing the fuel pump.
seabass1858 is offline
post #4 of 8 Old 11-04-2013, 09:53 AM Thread Starter
CW81Scrambler
1981 CJ8
The fuel pump is maybe three years old. Could it have gone bad just sitting there with very little use?
post #5 of 8 Old 11-04-2013, 10:11 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes it could
also, just how much gas do you put in to start it. It could run down past your rings into the crankcase but the pump is much faster.
John Strenk is offline
post #6 of 8 Old 11-04-2013, 10:21 AM Thread Starter
CW81Scrambler
1981 CJ8
Not a lot. It wouldn't be enough to raise the oil level that much
post #7 of 8 Old 11-04-2013, 10:30 AM
seabass1858
1983 CJ7
this happened to my 83 silverado during a 1 year deployment. It sat at the farm covered up for a year and long behold when i aired the tires, started it up after a femonths after a fresh oil change my levels rose.
post #8 of 8 Old 11-04-2013, 10:38 AM
mastercraftka
mastercraftka's Avatar
Yes it could
Ditto to the others and to what John said.
1984 CJ 7
1948 CJ 2A
1982 CJ 7
1981 CJ 7
mastercraftka is offline
