-   -   Gas in the Crankcase (http://www.jeepforum.com/forum/f8/gas-crankcase-1756545/)
CW81Scrambler 11-04-2013 09:37 AM
I checked the oil in my CJ8 yesterday and the level was high and smelled like gas. It's carbureted and won't start without putting some gas directly into the carb. Is there a way that gas is draining down into the crankcase?
only in a jeep cj 11-04-2013 09:45 AM
Yep, bad diaphram on your fuel pump. Don't run it till your change oil and pump.
seabass1858 11-04-2013 09:46 AM
x2. you are more than likely pumping fuel into your crankcase that explains the loss of prime on initial starts meaning you have to put fuel in your carb. Try replacing the fuel pump.
CW81Scrambler 11-04-2013 09:53 AM
The fuel pump is maybe three years old. Could it have gone bad just sitting there with very little use?
John Strenk 11-04-2013 10:11 AM
603 Attachment(s)
Yes it could
also, just how much gas do you put in to start it. It could run down past your rings into the crankcase but the pump is much faster.
CW81Scrambler 11-04-2013 10:21 AM
Not a lot. It wouldn't be enough to raise the oil level that much
seabass1858 11-04-2013 10:30 AM
this happened to my 83 silverado during a 1 year deployment. It sat at the farm covered up for a year and long behold when i aired the tires, started it up after a femonths after a fresh oil change my levels rose.
mastercraftka 11-04-2013 10:38 AM
Originally Posted by John Strenk (Post 17423809)
Yes it could
Ditto to the others and to what John said.
The time now is 09:13 AM.
