Gas check valve and anti roll over valve ? - JeepForum.com
post #1 of 2 Old 10-10-2006, 04:24 PM Thread Starter
NCHornet
I finally got the body Free on our 1977 CJ5, at least I thought it was free until I noticed two fuel lines running up into the drivers rear quarter panel. According to Chiltons these are the gas check valve and roll over valve. My question is how robust are these valves and is it a good idea to change them? They look pretty corroded from the outside. Are these a dealer item or something I can get at a local auto parts place? Thanks for the help.
Kevin/TJ
TJ's CJ5
1977 CJ5 4X4, Soft top
304 V8 project jeep for my
16 year old son and I
NCHornet is offline
post #2 of 2 Old 10-10-2006, 06:18 PM
Bard
I have never replaced them and as long as you can blow through the tube and get no resistance or appear to be operational, the vapors are going through it and I would go with they are good. I have a couple of CJ7's in my back field and can check them if you need them.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
roll over check valve mud4me Jeep CJ Forum 42 03-10-2017 10:44 AM
Replacements for Liquid Check Valve/Roll Over valve jpd1899 Jeep CJ Forum 143 08-25-2015 09:07 PM
83 OEM Poly Fuel Tank Roll Over check valve and gromet adheseve/sealer? gbeaklr Jeep CJ Forum 5 10-05-2009 10:07 PM
Deceleration Valve/Anti-Backfire Valve David Augusto Jeep CJ Forum 2 01-30-2009 07:09 PM
Rollover Check Valve & Fluid Check Valve -Parts search CJPoorhouse Jeep CJ Forum 2 06-13-2004 07:13 PM
