G 85 CJ7 Automatic - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > G 85 CJ7 Automatic
2014 Spartan Locker Special - While Supplies Last! Dana 3The Original 3/8" Ruffstuff Diff Cover!The RuffStuff "I can't go to EJS" Sale!
Unread 02-06-2014, 10:59 AM   #1
BiscuitTX
G 85 CJ7 Automatic
I have an 85 CJ7 3 speed auto. Large tires (33's) have slowed this bad boy way down and eats gas to the tune of 7 MPG. Does anyone happen to know whether an 85 automatic has a 2.73 or a 3.73 gears? Presumably the best thing to do would be upgrade to a 4.10?
thx
BiscuitTX is offline   Reply With Quote
Unread 02-06-2014, 11:53 AM   #2
wm69
Probably have 2.73's. Look at your rear axle housing and see.....
wm69 is online now   Reply With Quote
Unread 02-06-2014, 12:53 PM   #3
dandd
1982 CJ8
I have a 82 with auto and 4.11 gears and 35's. If there is minimal freeway this setup is good. At 65 mph I'm at 3000 rpm's. This is due to about a 200-300 rpm increase from the torque converter slip (non lockup). For offroad use I have a crawler box which gives me a total of 90:1 ratio to the rear wheels. If I had to do it over I would put in 3.73 or 3.9 to get lower freeway rpm's. This is a cj8 with a weight of 4150 lb's and I get 10-12 around town and 14-15 freeway.
Without a crawler box or low TC gears I would think you need to prioritize either more trail or more road. My rear had 2.73 gears originaly.
dandd is offline   Reply With Quote
Unread 02-06-2014, 12:56 PM   #4
BiscuitTX
Which one is which?
Unread 02-06-2014, 01:54 PM   #5
wm69
Well what do you have stamped on your housings where the above pictures indicate?
Likely D, DD, B or BB on an 85
Wide Track AMC 20 Code Gear Ratio Diff Type
D 2.73 Open
DD 2.73 Trac-Lok
B 3.31 Open
BB 3.31 Trac-Lok
A 3.54 Open
AA 3.54 Trac-Lok
H 3.73 Open
HH 3.73 Trac-Lok
C 4.10 Open
CC 4.10 Trac-Lok
Unread 02-06-2014, 04:23 PM   #6
BiscuitTX
Rear axle housing has DD so 2.73 explains the lack of power and gas guzzle. Thanks for your help.
