Fuse Block Help - JeepForum.com
post #1 of 7 Old 11-08-2011, 08:56 PM Thread Starter
rrtex1
1981 CJ7
Fuse Block Help
My dash lights, heater blower, and temp/fuel gauges are not getting power. Traced back to fuse box and that side of the box is not powered. Looking at the picture I have no power to Fan HTR, GN. LPS and BU/Seat. I do have haz lights though. Any ideas what would cause this? What to look for?
Round Rock, Texas
1981 CJ7 AMC304
rrtex1 is offline
post #2 of 7 Old 11-08-2011, 09:27 PM
bamasteeler
Make sure the fuse block is tight!! Check back side at firewall and make sure no breaks anywhere.
Maybe corrosion on that side of fuse block?? May have to take it apart and clean it? Good luck
1980 Jeep CJ7
AMC 258, T176, D300,
AMC 20 REAR, D30 FRONT
1999 XJ CLASSIC
RC 3" front AAL rear
bamasteeler is offline
post #3 of 7 Old 11-08-2011, 11:19 PM
titomars
1981 CJ7
those three fuses are powered by a bus bar. they are connected to a 10ga red with white stripe wire. this wire goes straight to the ignition switch. so i would imagine you need to first check the ignition switch if that's ok then trace the wire between the two
titomars is offline
post #4 of 7 Old 11-09-2011, 12:35 AM
BagusJeep
1981 CJ7
Similair to this though this is a slightly later layout. How about your wipers and turn signals?
I would have guessed it was actually a disconnect at the ignition switch if it was those circuits alone.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 7 Old 11-09-2011, 03:13 PM Thread Starter
rrtex1
1981 CJ7
Thanks for the replies. I was able to start tracing back to ignition and found a plug on top of steering column that was unplugged. All works now. Thanks!
Round Rock, Texas
1981 CJ7 AMC304
rrtex1 is offline
post #6 of 7 Old 11-09-2011, 06:18 PM
BagusJeep
1981 CJ7
Yahoooooo, an easy fix.
post #7 of 7 Old 11-09-2011, 09:49 PM
titomars
1981 CJ7
cool!! glad we could help
titomars is offline
Fuse Block Help JnH_78CJ7 Jeep CJ Forum 2 10-01-2011 07:35 AM
Where can I get just new Fuse Block only? specwarCJ Jeep CJ Forum 3 09-19-2010 03:48 PM
79 CJ 5 Fuse block kluman Jeep CJ Forum 4 04-28-2010 10:09 AM
Aux. Fuse Block????? Stan99 Jeep CJ Forum 30 06-26-2009 04:50 PM
fuse block? cshutts Jeep CJ Forum 2 04-15-2004 09:28 AM
