furthering the parts list... axles, flexplate, tc, gears.... - JeepForum.com
post #1 of 5 Old 04-29-2013, 02:01 PM Thread Starter
KGBnumber1
KGBnumber1's Avatar
based on my thread here:
http://www.jeepforum.com/forum/f8/ch...l#post15364162
i've decided to put a th350 + novak adapter + dana 20 behind my 3.8l v6 in my cj5(dj5 conversion). currently have a 700r4 and no tcase.
questions:
---engine->transmission---
not really jeep related, but since a lot of people use chevy drivetrains.... will i need a new flexplate and torque converter for the th350? i was reading the th350-700r4 are pretty interchangeable, all the way up to coolant line connection locations and shifter. but i need to check, id rather get all the parts in one trip out to the pick n pull.
---axles---
front:
currently just a straight tube original to the dj5. i'll be getting a dana 30 widetrack from a 82-86 cj for the front, as to have the disc brakes. i will most likely keep the stock 2.73/3.54 gearing, whatever i find. i'll need to get new spring perches most likely, and rob the steering linkage from the donor as well.
rear:
currently have a d44 rear narrow track, something like 3.73 gears, limited slip, with 2" aluminum spacers so it is wide track length. i would *like* to keep the limited slip. which of these two options would be my best bet (no rock crawling, maybe mild trail use/lil mud/ pittsburgh snow driving):
swap out to a amc20 from the same donor the dana30 comes from. the gears would probably already match, id get to ditch the spacers, and i'd gain disc brakes. do some amc20's have limited slip, or will i lose that? i would have to get new spring perches and do some welding with this.
keep the d44, keep the drum brakes, keep the 2" spacers, and regear to match the front 2.73/3.54. is the limited slip separate from the gear package or would i need to buy a limited slip gear setup? i wouldnt need new spring perches or do any welding with this.
thanks for sharing your knowledge
Blue Jeep Club member #100
1970 DJ-5
3.8 v6
700R4 tranny
countless hours of blood and sweat turning it into a cj-5
KGBnumber1 is offline
post #2 of 5 Old 05-01-2013, 11:15 AM Thread Starter
KGBnumber1
KGBnumber1's Avatar
anyone with an axle suggestion? i know the 44 is better but is it worth it to regear an axle that has drum brakes and 2" wheel spacers?
1970 DJ-5
3.8 v6
700R4 tranny
post #3 of 5 Old 05-01-2013, 12:02 PM
jeepwhore
The M20 has drum brakes as well so I wouldn't factor that into the equation when thinking about regearing. What size tires are you going to run? If it's gonna have at least 33's I'd stick with the gearing of the D44, regear the front to match. Anything higher (numerically lower) than 3.73 is gonna be a dog. The other option is if you can live with sub par performance do the matched set of WT axles with 3.31 or 3.54 gears (just be damn sure you avoid the 2.73's!). It'll save you in regearing costs (unless you can do the set up yourself)
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #4 of 5 Old 05-01-2013, 04:34 PM Thread Starter
KGBnumber1
KGBnumber1's Avatar
i thought the amc20 had disc brakes from 82-86? maybe it was just for the dana30.
i doubt i'll ever run 33's. maybe, maybe 31's if i feel frisky. but this will mostly be a heavy winter snow driver, with occasional mild off-road use. i say occasional as in maybe a grassy field or little trail. so i'm not too worried about the amc20 strenth issues. if i were, id definatly keep the 44. i'm more interested in the limited slip rear from the 44.
i think what it comes down to is if i find a set of widetrack axles that has the trak loc amc20. that way i wont have to do any re-gearing at all, just a basic swap in. and i should be able to sell the 44 in that case to recoup some of the losses. i found a website that i can print out with all the axle codes on the case to tell me what gearing it is and if it is trak lok.
1970 DJ-5
3.8 v6
700R4 tranny
post #5 of 5 Old 05-01-2013, 05:13 PM
jeepwhore
Nope, no jeep prior to the ZJ came with 4 wheel discs.
Since your staying on the small side I agree. Go with a matched wide track pair in 3.31 or 3.54 gears. That should be good for your intended use.
