Full Hard Door ADjustments - JeepForum.com
post #1 of 4 Old 04-14-2005, 10:13 AM Thread Starter
Scrambler82
Scrambler82's Avatar
1982 CJ8
Anyone have any good pointers on adjusting doors.
I have installed new doors, aligned the body lines, thedoors close on the door latch pins OK, but the passenager side is a little low in the back side.
I tried to raise the whole door up and then twist teh front a little lower but no luck, the door keeps going back to the last position.
Any help here would be appreciated.
Later,
p.s. I did notice one thing and this may not be a biggy, the passenager's side door is approx 7/16 shorter than the driver's side door.
This could be my problem, I think that is all I need to get teh passenager's door to align.
Anyone ever hear of doors being short.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #2 of 4 Old 04-14-2005, 01:34 PM
ollietonk
I just put some doors on my CJ and had to loosen up the two hinges on the door to get the adjustment correct. I tried not to do this (didn't want to mess up the paint) but couldn't get them right. Once I loosened those hinges, I wiggled the door maybe 1/8 of an inch and everything lined up. The doors close nicely, the windsheild sits good and seams line up. Those door striker pins are easily loosened and moved so that was the last thing I made fit. I did try to use some bolts and washers on the passengers door to hold the hinges on (had to drill the originals out to remove the hinges) but the doors would slowly sag. I put some of the taper (like the original ones) bolts in and they fit the hole better. No more saggin'. Hope this helps and Goodluck
86' CJ7 (258 w/ Howell TBI, 33" ProComp MT's)
ollietonk is offline
post #3 of 4 Old 04-14-2005, 03:44 PM
CJ-22
CJ-22's Avatar
This may or may not be a good idea, but it worked for me. When I aligned my hard doors I loosened the door hinges and placed a folded towel under the door. I shut it and used the towel as a soft shim. If it looked like the door needed to be raised I put more folds in the towel. If it looked like the door needed to be lowered I took out some folds in the towel. Once I got the door where I wanted it I tightened the hinges and removed the towel. It worked out great for me, but maybe I just got lucky. Hope this helps.
78 CJ-7, 360, 4 inch lift, 33" tires, 4.10 gears, TH 400 tranny, quadratrac t-case, dana 30 front, AMC 20 rear with Superior One Piece Axle.
CJ-22 is offline
post #4 of 4 Old 04-14-2005, 04:03 PM
redlinedcj
i just has someone pull up on the door the tighten it back up and it worked perfect if its really off the you could take a file to the hinge and make the holes a little larger and use a washer on the end you should be about to get a bit more movement out of it if you do that.
redlinedcj is offline
Interior full hard door panel question... shinerm02 Jeep CJ Forum 3 01-23-2010 09:42 AM
hard full door latch damaged... mrk3cobra Jeep CJ Forum 3 01-24-2009 05:55 AM
Door/Top Adjustments tumbleweed58 Jeep CJ Forum 3 01-25-2008 12:28 PM
Full Hard Door Latch Blue83CJ7 Jeep CJ Forum 2 09-27-2006 11:01 PM
New Full Hard Door Install Scrambler82 Jeep CJ Forum 4 09-15-2003 04:17 PM
