FULL AMC 20 rebuild and setup - Page 4 - JeepForum.com
post #46 of 71 Old 06-24-2011, 04:32 AM Thread Starter
stgil
1982 CJ7
Originally Posted by LT1CJ7 View Post
No not really.
It just looked like the primary & secondary shoes looked to have the same length of material.
Usually the primary has less.
I've checked this at mount time... but now when I see my pics , It's looks like you're RIGHT
Here the old one : we clearly see the difference... It's NOT the case with NEW ones... I think REALLY I've done a mistake and mixed THEM!!!...
I'll check it again this afternoon...
I'll tell you...
Regards,
Gilles
FULL DANA 30 REBUILD->
CJ7 LAREDO REBUILD->http://www.jeepforum.com/forum/f8/82-cj7-laredo-diesel-restoration-1179198/
stgil is offline
post #47 of 71 Old 06-24-2011, 05:21 AM Thread Starter
stgil
1982 CJ7
Well!
I've checked my other pics on the other side ... and you're definitively RIGHT there is only the smaller( primary shoes) :I've mixed them!!!
I'm VERY sorry about this mistake and I'll fix it as soon as possible
Very thanks! LT1CJ7
Regards
Gilles
stgil is offline
post #48 of 71 Old 06-24-2011, 05:22 AM Thread Starter
stgil
1982 CJ7
and...I have no mitigating with ALL this pics!!!
stgil is offline
post #49 of 71 Old 06-24-2011, 06:19 AM
Sevenseejay
1981 CJ7
I learned something.. Thank you LT1CJ7!
Oh no! On my CJ I have mounted my shoes conversely!
On the manual this difference is not in evidence..! I have read only primary and secondary shoe.. there difference only on the drawing, but can't see unless you know.
With the less shoe in the secondary position what happens?
What is the function of this difference?
Thanks..
No not really.
Sevenseejay is offline
post #50 of 71 Old 06-24-2011, 08:39 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Very thanks! LT1CJ7
Regards
Gilles
Your very welcome!
No need to apologize,
Even the best of us goof or learn something new once in a while.
Keep up the good work.
LT1CJ7 is offline
post #51 of 71 Old 06-24-2011, 08:50 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Thanks..
Your very welcome.
The smaller primary shoe will catch the drum surface and energizing the secondary into a rotational force pair.
The rotation of the drum will drag both of the shoes into the friction surface of the shoes, causing the brakes to bite harder, which increases the braking force.
I would change them around to be proper.
LT1CJ7 is offline
post #52 of 71 Old 05-21-2012, 05:54 PM
jcalhoon84
1980 CJ5
Shims
Just the left side that has a special features ...
It has a shim between the trumpet of the axle housing and the flange which we will try to find the right the thickness now...
So a shim (currently at random OR you can put your OLD shim)
the 4 new screws (ALWAYS GRADE 8)
To be continued...[/QUOTE]
When you say left are you talking the driver's side or the passenger side? Thanks for the write up!
jcalhoon84 is offline
post #53 of 71 Old 05-22-2012, 01:17 AM Thread Starter
stgil
1982 CJ7
Hello,
This is, of course, the driver side
Thanks for the congrats
Regards,
Gilles
stgil is offline
post #54 of 71 Old 03-19-2013, 10:16 PM
77repeej
1977 CJ7
20 rebuild
Stgl, Can I just use the old shims off the carrier and the pinion if all I did was replace the original carrier with a limited slip stock unit? Even if I replaced all the bearings and crush sleeve. Thanks for your input.
77repeej is offline
post #55 of 71 Old 03-19-2013, 10:22 PM
77repeej
1977 CJ7
model20 rebuild
Can I reuse the shims on the carrier and pinion if all I changed was the carrier? I made the mistake of not getting measurements on the pinion before I pulled it. Any help is great. I want to keep my 20. Thanks
77repeej is offline
post #56 of 71 Old 03-20-2013, 01:06 AM Thread Starter
stgil
1982 CJ7
Hello,
Not at all: you change one component (the carrier) so every measure must be checked. In other words you CAN'T reuse your old shims without checking all the measure: Backlash, pinion depth and so on...
BTW... you not only change the carrier... you replace its bearings too
Good luck...
Regards,
Gilles
stgil is offline
post #57 of 71 Old 03-20-2013, 03:15 PM
77repeej
1977 CJ7
amc20 rebuild pinion
stgil, can I check and set the pinion up without having the pinion depth tools?
77repeej is offline
post #58 of 71 Old 03-20-2013, 06:20 PM
keith460
Jeep. There's Only One
keith460's Avatar
To be continued...
Add or delete shims until 0.004" - 0.008" End Play is achieved. You need a dial indicator mounted to check this.
1984 CJ-7 Renegade
keith460 is offline
post #59 of 71 Old 03-21-2013, 03:49 AM Thread Starter
stgil
1982 CJ7
Hi Keith !
as shown >>> HERE <<< too, did I a mistake ?
@77repeej:
without depth tools... the only other way is the pattern reading (paint on gears)... a little bit fuzzy (and long) for beginners...
Regards,
Gilles
stgil is offline
post #60 of 71 Old 11-13-2015, 12:16 PM
wm69
Know this is an old thread, but where did you get the "final shims" you used on the carrier?
Stacking thin shims thick enough to get the proper preload could make getting the carrier in place be horrible. I notice you didn't have to use a case spreader using the thick OEM type one piece shims.
wm69 is offline
CJ7 DANA 30 Full Rebuilt and Setup PART I stgil Jeep CJ Forum 43 12-16-2015 03:57 AM
From replacing oil pump to full rebuild locked-up-XJ Jeep CJ Forum 19 03-16-2013 11:03 AM
full linked setup? hmm what to do!? 79jeepincj7 Jeep CJ Forum 21 10-06-2010 11:28 AM
Carter BBD rebuild: Does it matter which rebuild kit I use? Ken4444 Jeep CJ Forum 2 06-14-2010 11:01 AM
eh full top VS. full width irons neatocj Jeep CJ Forum 13 07-12-2008 12:12 AM
