-   -   FULL AMC 20 rebuild and setup (http://www.jeepforum.com/forum/f8/full-amc-20-rebuild-setup-1176780/)
stgil 03-04-2011 02:00 AM
Hello
Here I am (again)
Now for the AMC 20 setup...
So for AMC 20 you will need:
ring / pinion gear kit ratio ... 4.56 (ref 8134410 by SUPERIOR ref AMC456)
NB: I have NO action in SUPERIOR!
http://i33.servimg.com/u/f33/14/73/92/26/p1050312.jpg
and a bearing kit and accessories (ref 35-2025 SUPERIOR)
It includes:
-Bearings (of course)
-Nut pinion
-pinion seal
-nuts ring
-Cover seal
-shims for the pinion detph and backlash
-collapsible spacer
-Glue for cover seal
I think that's all!
Oh yes! A big nice SUPERIOR sticker !
http://i33.servimg.com/u/f33/14/73/92/26/p1050313.jpg
First we ensure that the pinion and ring are well paired.
How we do this? Well as for the DANA 30 ... There must be a number engraved on the IDENTICAL pinion and ring ...
On the pinion:
http://i33.servimg.com/u/f33/14/73/92/26/p1050314.jpg
and ring:
http://i33.servimg.com/u/f33/14/73/92/26/p1050315.jpg
Same number! So they are paired!!!
Those who have followed the rebuild of DANA 30 ... there is a problem ... on Dana 30's pinion there was also the pinion depth...
If you did not ... it's very bad ...
keep cool, SUPERIOR's guyz have tapered the pinion depth (RED) and the backlash (GREEN) on the ring
http://i33.servimg.com/u/f33/14/73/92/26/p1050316.jpg
We have:
pinion depth 2.551 "(ie a +4 in old school style to the nominal pinion depth of 2.547") or 64.79 mm
Backlash is 0.006 "or 0.15 mm
Pinion depth , backlash, old-fashioned pinion depth ... it tells you nothing?
Ah! You can not even imagine that I redo the ALL course! not even DREAM..Everything is >>> HERE <<<
First BEFORE anything ...we need to remove the brake part of the OLD pinion nut in order to allow easy insertion during setup ...
So: screw, vise, wooden board (to avoid distorting the nut), and of course grinder and of course :APPROPRIATE PROTECTIONS:
http://i23.servimg.com/u/f23/14/73/92/26/p1060027.jpg
and here it is:
http://i23.servimg.com/u/f23/14/73/92/26/p1060028.jpg
We recovered now the old bearing cone inside of the old pinion to make him suffer too ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060029.jpg
the torture of the grinder ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060030.jpg
In the slit ... we insert a piece of steel for easy insertion / removal of the cone when installing the new inner bearing ...
Without it ... although the cone is cracked ... Is not a piece of cake...
http://i23.servimg.com/u/f23/14/73/92/26/p1060031.jpg
Ready ? Set ? GO !
The pinion depth:
We need it all:
A Yoke whole fresh back from painting
A pinion,
A set shims,
A inside bearing: TIMKEN M802048 (cone) / M802011 (cage)
An outer bearing: TIMKEN M88048 (cone) / M88010 (cage)
A collapsible space for the preload
a NEW nut for pinion
and of course a new gasket seal.
http://i23.servimg.com/u/f23/14/73/92/26/p1060032.jpg
We begin by setting the bearing cone on the pinion, we oil the part that will receive the cone bearing in order facilitate the integration ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060033.jpg
we installs the bearing in the right direction
http://i23.servimg.com/u/f23/14/73/92/26/p1060034.jpg
And the interior cone that we have previously hacked ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060037.jpg
We add a BIG shim on the top of the pinion, and we press
http://i23.servimg.com/u/f23/14/73/92/26/p1060038.jpg
Hurry!!! hurry!!
http://i23.servimg.com/u/f23/14/73/92/26/p1060039.jpg
when the manometer of the press raise ... it is time to release this little world ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060040.jpg
and we now proceed to calculate the pinion depth ...
First you need a ride on OLD pinion that had included this:
The last number is not very clear... Well, we will assume that it's a 1!
http://i23.servimg.com/u/f23/14/73/92/26/p1040510.jpg
Go! it detailed! 34 is the number of matching with the ring that falls well: it is the same as the former ring:
http://i23.servimg.com/u/f23/14/73/92/26/p1060041.jpg
and "+1" means 1/1000 of an inch over the nominal the pinion depth! 2.547"+0.001" = 2.548" or 64.72 mm
The old shim for pinion depth was 0.098" (2.49mm):
http://i23.servimg.com/u/f23/14/73/92/26/p1060042.jpg
To be continued ... soon
Gilles
vincent57 03-04-2011 02:22 AM
Hey,
Good topic that you make ! ;)
Thanks
Vincent :)
george29223 03-04-2011 04:02 AM
top notch wish i could do that! btw i can never get used to using latex gloves while working i always end up placing them on my head and acting like a 400 pound blue coned rooster
Shiftace 03-04-2011 08:41 AM
Fun, isn't it?
I had to move the Jeep to the garage because the owl wouldn't leave me alone in the barn.
stgil, thanks for this step by step! I'm getting ready to do my AMC20 also and this write up is just in time.
stgil 03-05-2011 12:14 AM
Thanks Guyz for your replies...
And back to the topic...
We know NEW pinion depth is 2.551 "(either a +4 in old school style (see above in the post)) or 64.79 mm
So we will have to reduce the thickness of shim 7 / 100 min of: 64.72-64,79 = 0.07mm is ~ 3 / 1000 of an inch!
We must reach a shim to be 2.49-0.07 = 2.42mm or ~ 0.095"
Here we have our available shims:
http://i23.servimg.com/u/f23/14/73/92/26/p1060043.jpg
We'll use:
0.02"+5x0.012"+0.015" =0.095" or about ~2.41 mm it is not far from the right thickness!
http://i23.servimg.com/u/f23/14/73/92/26/p1060044.jpg
So Rock'n'roll!!!: we install the outer bearing cup ... on the housing
http://i23.servimg.com/u/f23/14/73/92/26/p1060045.jpg
with 68mm washer on the top of the cup and ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060046.jpg
few blows of mallets
http://i23.servimg.com/u/f23/14/73/92/26/p1060047.jpg
and Voila!
http://i23.servimg.com/u/f23/14/73/92/26/p1060048.jpg
Tada!
http://i23.servimg.com/u/f23/14/73/92/26/p1060049.jpg
we return to the differential housing to install the inner cup... first... we oil the machined part that will receive the bearing cup...
http://i23.servimg.com/u/f23/14/73/92/26/p1060110.jpg
we install the shims... (2.42mm)
http://i23.servimg.com/u/f23/14/73/92/26/p1060111.jpg
and then the inner bearing cup...
http://i23.servimg.com/u/f23/14/73/92/26/p1060112.jpg
a washer of 82mm the top ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060113.jpg
and a pipe with 6mm diameter and 20cm long and then another washer ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060114.jpg
beat time and here's the result:
http://i23.servimg.com/u/f23/14/73/92/26/p1060115.jpg
we ensure that shims do not move ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060116.jpg
We install the pinion...
http://i23.servimg.com/u/f23/14/73/92/26/p1060117.jpg
We will install the other side of the inner bearing in the right direction ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060118.jpg
then the yoke...
http://i23.servimg.com/u/f23/14/73/92/26/p1060119.jpg
and now, the OLD bolt (which has been hacked) ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060120.jpg
We install the immobilizer on the yoke...
http://i23.servimg.com/u/f23/14/73/92/26/p1060121.jpg
To be continued ... soon...
stgil 03-06-2011 02:51 AM
and the nut must be tightened ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060122.jpg
... Until you get a slight preload 2-3Nm (or 5-6 kg ... see my DANA 30 post >>> HERE <<< for more explanation: I do not like doing things 2 times)
...5.5 Kg WONDERFULL!!
http://i23.servimg.com/u/f23/14/73/92/26/p1060123.jpg
Back in the housing in order to set the pinion depth measure tool (I'll describe it in detail at the end of the post)
http://i23.servimg.com/u/f23/14/73/92/26/p1060124.jpg
And the bearing caps (always well identified (right and left)) ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060125.jpg
Here it is the complete measure tool set ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060126.jpg
We set zero on the comparator gauge
http://i23.servimg.com/u/f23/14/73/92/26/p1060127.jpg
we scoop the gauge under the fake axle...
http://i23.servimg.com/u/f23/14/73/92/26/p1060128.jpg
Until the minimum value (do it many times the measure for consistency) ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060129.jpg
Well... we read -0.12mm
the block shim (on the top of the pinion gear) is 74.89mm, the nominal pinion depth of the pinion gear is 74.79mm (2.551") and the measurement read is -0.12mm
74.89mm
-0.12mm
74.77mm not bad at all! it is 2/100mm (74.79mm-74.77mm = 0.02mm) from the ideal distance ... there is a tolerance or -5/100mm (0.002")...
So...It's all good! and at the first time!!!!
Yeeeee AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAhhhh!:
Easy isn't it? with the right way and the right tools!!!
To be continued... soon
stgil 03-06-2011 10:09 AM
Now it's
differential bearing preload and backlash time!!!!
To do this, you will need:
-A ring
-2 differential bearings: TIMKEN LM603049 (cone) / LM603012 (cage)
-8 NEW bolts for the ring
-A differential cage-limited slip littered (trac lok)
This cage was new (Crown Brand :mad:)... but I could very well could resume my old one... And finally I take the used one at last (I'll explain at the end of the post:( )
http://i23.servimg.com/u/f23/14/73/92/26/p1060210.jpg
First we oil the machined part of the differential to facilitate reassembly of the bearings ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060211.jpg
We set the cage on the press and the bearing cone too... IN THE RIGHT DIRECTION
At end we set the OLD cone ... above ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060212.jpg
... and then a big shim ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060213.jpg
and now we press all together ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060214.jpg
when the press manometer raise up... we stop! ...
... seen on the ring side:
http://i23.servimg.com/u/f23/14/73/92/26/p1060215.jpg
Back on the axle housing... where we remove the bearing caps (which are kept apart ALWAYS (right / left ))...
http://i23.servimg.com/u/f23/14/73/92/26/p1060216.jpg
... then removing the measuring tools...
http://i23.servimg.com/u/f23/14/73/92/26/p1060217.jpg
we install on the right a shim of 2.00mm thick ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060218.jpg
... left too (same thickness) ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060219.jpg
and we install now the differential cage with bearings...
http://i23.servimg.com/u/f23/14/73/92/26/p1060220.jpg
And we install the bearings caps ...
http://i23.servimg.com/u/f23/14/73/92/26/p1060221.jpg
To be continued... soon ;)
stgil 03-07-2011 01:11 AM
We tight the nuts...
http://i23.servimg.com/u/f23/14/73/92/26/p1060222.jpg
We set the comparator dial so that the measurement is performed on the mounting ring ... we reset(0) the dialer while the plating on one side ...
http://i33.servimg.com/u/f33/14/73/92/26/p1060310.jpg
and we push the cage to the other side (still dark :D ) ... and read ... 0.46 mm (we perform several SAME measure for accuracy)
That means putting a shim 0.01 "(0.50mm = 0.25mmx2) distributed equally on each side of differential
The fact that I put a little more (0.01 "(0.25mm) instead of 0.23mm) ... you'll see why ...
http://i33.servimg.com/u/f33/14/73/92/26/p1060311.jpg
So we dismantled the right bearing caps ...
http://i33.servimg.com/u/f33/14/73/92/26/p1060312.jpg
and left ...
http://i33.servimg.com/u/f33/14/73/92/26/p1060313.jpg
and then we insert on each side a 0.01 "shims ... one side
http://i33.servimg.com/u/f33/14/73/92/26/p1060314.jpg
and two ...
http://i33.servimg.com/u/f33/14/73/92/26/p1060315.jpg
a short overview ...
http://i33.servimg.com/u/f33/14/73/92/26/p1060316.jpg
We put AGAIN bearings caps, the comparator reset ... and normally ... if we push the cage the comparator should no longer move ... it's good ...
http://i33.servimg.com/u/f33/14/73/92/26/p1060317.jpg
... And if you pull to the other side : it's the same ... it's all good: there is NO more gap...
http://i33.servimg.com/u/f33/14/73/92/26/p1060318.jpg
We Dismount the comparator ... and ensures that when you turn the differential, we MUST feel a "slight bearing drag" that's why I put
a little more thickness of shims: 0.25mm instead of 0.23mm...
If it's no the case : add more shim on each side of bearing until you notice it...
http://i33.servimg.com/u/f33/14/73/92/26/p1060319.jpg
Now we set AGAIN the comparator in order to measure the runout of the cage
The maximum runout should be 5 / 100 mm: I'm lucky : I have 3 / 100 mm with my old cage...
BUT the NEW CROWN cage exceed it : 16/100 mm!!! :mad: (see at the end of post for more informations)
http://i73.servimg.com/u/f73/14/73/92/26/p1060923.jpg
when done ... we have to set the ring on the cage ...
We ensure that the support cage ring is clean ... otherwise use cloth and compressed air to remove dirt ..
http://i73.servimg.com/u/f73/14/73/92/26/p1060924.jpg
we center screw holes and set NEW screw
http://i73.servimg.com/u/f73/14/73/92/26/p1060925.jpg
and we tightened them to 75nm ...
http://i73.servimg.com/u/f73/14/73/92/26/p1060926.jpg
... with the following sequence ...
http://i73.servimg.com/u/f73/14/73/92/26/p1060927.jpg
Next step ... soon ;)
keith460 03-07-2011 03:48 AM
Both the right up of the DANA 30 and this on the AMC 20 should become a "sticky".
Well documented photos and lots of info with measurements that can be converted for the metric challenged when making tools.
BESRK 03-07-2011 05:37 AM
Nice writeup!! Linked this thread in the CJ FAQ Sticky :thumbsup:
stgil 03-07-2011 12:03 PM
Many many thanks Guyz!!!:cheers2: :thumbsup:
I'm very happy that you like it...:thumbsup:
I've done much more post like this ...i.e. DANA 30 Steering, Steering column, electrical, and so on... on the French Forum...
But it takes time to translate (once again sorry for my English)
Next coming soon...
Regards,
Gilles
stgil 03-08-2011 12:59 AM
we shall put the shims (previously measured) in the housing ...
http://i73.servimg.com/u/f73/14/73/92/26/p1070010.jpg
Then the differential (Be care full of the teeth of the ring and pinion gear and it is desirable to be 2 ...
... because the differential is pretty heavy, it would be nice to have 4 hands to hold in place the shims during inclusion of differential cage)
http://i73.servimg.com/u/f73/14/73/92/26/p1070011.jpg
... then the bearing caps (always different) that is tightened to 110 Nm
http://i73.servimg.com/u/f73/14/73/92/26/p1070012.jpg
Then we make sure that there is some slack in trying to turn the differential ...
http://i73.servimg.com/u/f73/14/73/92/26/p1070013.jpg
It is not our case (no slack at all) So we dismount everything and removing a shim 15/100mm (0.006") (ring side)
http://i73.servimg.com/u/f73/14/73/92/26/p1070014.jpg
to put the other side ... theoretically, the displacement of a 15/100mm (0.006") shim adds (or remove (depends the side
where you put the shim: in our case we ADD backlash)) a backlash of 7/100mm (0.003")
http://i73.servimg.com/u/f73/14/73/92/26/p1070015.jpg
We put bearing caps (always properly torqued)
This time we have slack and we can install the dial indicator to measure backlash ...
Bad luck we have 12/100mm (0.005") backlash ... but we must have 0.006 " (0.15mm) (see above for optimal backlash (figure on the ring))
Note that the FSM do not worries about this statement: backlash should be between 0.12mm (0.005") and 0.20mm (0.008")
But we try to do this quite perfect...
http://i73.servimg.com/u/f73/14/73/92/26/p1070016.jpg
So we move AGAIN (always in the same direction) a 15/100mm(0.006") shim to see if it approaches the 0.15mm (0.006") backlash ...
Bearing caps propelly torqued and so on... you begin to know how not? and again measured the backlash:
0.19mm (~0.007) Yeah not bad ... but could do better ...
http://i73.servimg.com/u/f73/14/73/92/26/p1070017.jpg
We stop there (for now) for the backlash because now we have to add shims to the differential bearing preload.
10/100mm(0.004") shims on each side of differential cage . Hmm ... since we have a little too high backlash ...
I suggest you to add only 8/100mm (0.003") on ring side ...
http://i73.servimg.com/u/f73/14/73/92/26/p1070018.jpg
and 12/100mm (0.005") on the other side (it always makes at total amount of 20/100mm (0.008") differential bearing preload)
http://i73.servimg.com/u/f73/14/73/92/26/p1070019.jpg
we replace the differential ... WARNING: this time is a bit harder because the preload bearing is in place ... we should use
a lead hammer to finish setup:
http://i73.servimg.com/u/f73/14/73/92/26/p1070020.jpg
... be carefull with the ring...
http://i73.servimg.com/u/f73/14/73/92/26/p1070021.jpg
voilaaa:
http://i73.servimg.com/u/f73/14/73/92/26/p1070022.jpg
we tighten the bearings caps still 110Nm ...
http://i73.servimg.com/u/f73/14/73/92/26/p1070023.jpg
and again we measure the backlash ...
15/100mm (0.006")! PERFECT!!!
Of course we must make several measurements around the ring and the gap between measurement should
not exceed 2/100mm! (0.001") : It's still our case ...
http://i73.servimg.com/u/f73/14/73/92/26/p1070024.jpg
Guess what lies ahead?
http://i73.servimg.com/u/f73/14/73/92/26/p1070030.jpg
yes! gouache time, there is one that has put his hand to the paw, or should I say truffle...
and here is the result which is PERFECT
http://i73.servimg.com/u/f73/14/73/92/26/p1070026.jpg
This part is ONLY for control since we do the measure with the right tools...
Good! you know what ? ... we must remove ALL ...
to replace the interim shims by final shims in one piece ...
I'm TOTALLY agree with the Grear post ( >>> HERE <<<) : Shims delivered in the SUPERIOR
kit are weak and inapropriate: It must be replace with one piece shims (like OEM)
We must remove the differential cage ... Since there is a preload ... it's not easy...
FSM says to use large screwdriver (or a crowbar) and pull to remove it... It's not very safe for the teeth of the ring and pinion gear
So Here is my method (French touch):
a ratchet strap installed in the center differential is extremely tense
http://i73.servimg.com/u/f73/14/73/92/26/p1070027.jpg
A few blows of lead hammer on the right and left of the housing ...
http://i73.servimg.com/u/f73/14/73/92/26/p1070028.jpg
and voila
http://i73.servimg.com/u/f73/14/73/92/26/p1070029.jpg
So you're now in LIVE time... I'm waiting for the final shims... hope soon!!!
sdrewel 03-08-2011 01:39 AM
where did you use the collapsible spacer? I thought it went in on the pinion to set bearing preload?
stgil 03-08-2011 01:54 AM
Hi,
I do not use at this time the collapsible spacer... because I need to replace interim shims of the pinion depth and I need to dismount the pinion gear...
Collapsible spacer, yoke seal, yoke nut are 'one use purpose only':
If you set them and remove them, YOU NEED TO CHANGE them.
I'll use them when I'll do the PRELOAD PINION GEAR... be patient ;)
Regards,
Gilles
ctm 03-08-2011 04:38 AM
Excellent work. Thank you for taking the time to do these writeups.
The time now is 11:11 AM.
