#1 | |
Fuel & Temp Guage
I have a 1981 CJ7. The gas & Temp gauges do not work. I just replaced the temperature sending unit & the wire seems to be okay.
Does anyone have a diagram of the back of the cluster? maybe the wires aren't on the right connector. I did find 2 wires (red & orange) that are not connected. I tried monkeying with them but I'm not sure where they go. Thanks for your help, Ron
#2 |
Underground Jeeps
Hey Ron, try here..
http://www.jeeptech.com/electrical/gauges/ I'm terrible when it comes to electronics, but that's a good start.
Mike 1986 Jeep CJ7 (photos) Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work |
#3 |
The easiest way to check is with an ohm meter. This way you know if it's your sender/wiring or the gauge itself. The coolant sending unit and fuel tank sending unit are constantly sending out resistance (if they work) and you can test this with an ohm meter to see if they are sending anything.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress) 1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress) |
#4 |
What was I thinking
There is a picture here:
http://users.adelphia.net/~john.strenk/Gauge%20web%20page/QuickFacts.htm Check these out also: http://users.adelphia.net/~john.strenk/Gauge%20web%20page/basic_troubleshooting_for_cj_gau.htm and http://users.adelphia.net/~john.strenk/Gauge%20web%20page/CJSpeedometerGaugeQuickTest.htm |
#5 |
Running On Empty...
John is Da' Man!
Don't ask questions until you have downloaded and printed out everything John has on his web sites, and have read it completely a dozen times... Then you will be educated enough to ask coherent questions if you didn't find the answer outright...
REMEMBER, 'Free' internet information is worth EXACTLY what you paid for it! LINK:Dual Battery Diagrams & Explanations. LINK:Winch, Welding, 'Lend Power' Project, LINK:Water Proofing Ignition, Hubs, Ect., LINK:BSERK's Winch Plate, LINK:AMC V-8 Front Cover Recondition, LINK:How An Ignition Works, LINK:Ignition Swaps '77 Older Jeeps, LINK:'78-'90 Jeep Ignition Upgrades, |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
