Quantcast Fuel and Temp guage - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Fuel and Temp guage
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 10-23-2007, 06:06 AM   #1
jsiemen
Fuel and Temp guage
I just installed an upgraded guage set from 4WD. They are from Rugged Ridge. I am getting different reading from the OEM ones that were in there. The fuel reads 3/4 when full and the temp reads more hotter than the older guages. I had to replace the OEM as the fuel guage resistor went out. Has any one used these guages before and any ideas how to corect the readings? Thanks.
jsiemen is offline   Reply With Quote
Old 10-23-2007, 06:32 AM   #2
John Strenk
What was I thinking
1976 CJ5
I don't know about Rugged Ridge Gauges but most gauges are adjustable one way or another.
Are they round or trapizoidal in shape? Were they a direct replacement gauge?
Do they look like any of these?:
http://www.jeep4x4center.com/jeep-cj8/gauges.htm
Also read this:
http://www.cjoffroad.com/forums/topic.asp?TOPIC_ID=5973&SearchTerms=gauge,adjust
John Strenk is offline   Reply With Quote
Old 10-23-2007, 06:54 AM   #3
jsiemen
That looks like them the trapizoidal. I will have to pull them back out to see if there is an adjustment on them, or do could you tell me if and how before I pull them. Thanks.
Old 10-23-2007, 09:17 AM   #4
aero mech
aero mech's Avatar
1980 CJ7
I believe the fuel gauge adjust at the sending unit as for the temp gauge maybe you old gage was alittle off. I know there is a site out in ciberspace that tells what the omphs shoule be on the guages at full and empty and hot and cold. A factory manual also has this info in it. Hope this helps. jc
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline   Reply With Quote
Old 10-23-2007, 09:34 AM   #5
79cj7reny
1979 CJ7
Try this link from John Strenk. Very helpful.http://users.adelphia.net/~john.strenk/Gauge%20web%20page/basic_troubleshooting_for_cj_gau.htm
79cj7reny is offline   Reply With Quote
Glock Forum
