-   -   Fuel and Temp Gauges Don't Work (http://www.jeepforum.com/forum/f8/fuel-temp-gauges-dont-work-1393529/)
blk83cj7+4 07-15-2012 08:54 PM
No back light for speedometer. No high-beam indicator light. Directional indicator lights DO work. :confused::rolleyes: Do oil pressure and battery gauges have backlights?:cheers2:
Where do I start troubleshooting?
Trapshooter 07-15-2012 08:58 PM
One of our Moderators on the CJ forum is John Strenk. Do a search and you will find all the answers for your gauge issues. John is the man when it comes to fixing gauges problems.
Good Luck............
BagusJeep 07-16-2012 12:04 AM
As most of what you refer to are lights I would check the fuses, then check at the light switch that you are feeding voltage to dash lamps.
When you look up behind the gauge cluster you can see the wires and bulbs. Are they getting voltage?
Best tool is a test lamp and long leads. Hook one end up to battery -ve and start pprobing for voltage.
Crazyray2929 07-16-2012 12:26 AM
When I had no lights I turned my dimmer switch up first...
John Strenk 07-16-2012 02:12 AM
603 Attachment(s)
What about the lights for the controls on the dash like heater and vent. Do they light up or all all dash lights dead?
CJ5COLORADO 07-16-2012 06:51 AM
I am having this same issue. I have installed mechanical temp, oil and volt guages.
blk83cj7+4 07-16-2012 08:54 PM
Thanks everyone for the replies. I guess I must learn to use that voltage tester collecting dust over there. Where the heck is the dimmer switch? lol. This Jeep was missing a few things when I got it, like the fast idle assembly. So I have a new carb on order. The jeep supposedly sat for 6 years. There is no power in 4th or 5th gear, so I must avoid the interstates until I figure it out.:crying:
blk83cj7+4 07-16-2012 08:57 PM
Oh, and yes, all dash lights are out except for the turn signals and hazards.
John Strenk 07-17-2012 02:53 AM
603 Attachment(s)
Dimmer switch is on the headlight switch. Turn it one way or the other to brighten or dim your lights.
If you turn it in one direction you will feel a click and that should be full brightness. If the lights don't work then,
Time to get the test light out. And start testing fuses.
What happens is corrosion builds up on the wiper of the dimmer potentiometer and looses contacts' The windings have been known to fall out and short blowing fuses.
http://civilianjeep.info/Strenk/Ligh...Connection.jpg
Short above
http://civilianjeep.info/Strenk/Ligh...tchReostat.jpg
Corrosion and Loose windings could lead to shorts.
Maybe someone can confirm what direction is full brightness.
blk83cj7+4 07-17-2012 06:00 AM
Can the dimmer switch be restored?
John Strenk 07-17-2012 06:26 AM
603 Attachment(s)
I've never tried but probably some cleaning and some epoxy can but it back into shape.
Switches didn't use to cost to much.
blk83cj7+4 07-18-2012 04:01 AM
Thanks John, is there a special tool to remove the switch from the dash? It looks that way from the cab side.
John Strenk 07-18-2012 06:22 AM
603 Attachment(s)
FIrst pull the knob and rod off. There is a button on the bottom that you press in and you can slide it out all the way.
Then use a needle nose pliers to remove the nut and bezel
http://i123.photobucket.com/albums/o...zelRemoval.jpg
Truck633 07-18-2012 07:43 AM
just a quick make sure you disconnect the battery, when you press the button and remove the rod, the lights come on, and will stay on until you unplug the harness..... Ask me how I know this!:thumbsup:
blk83cj7+4 07-22-2012 10:58 PM
Thanks guys. They is no knob so I don't have to worry about that.:D
The time now is 03:45 PM.
