Fuel and Temp Gauges Don't Work - Page 2 - JeepForum.com
post #16 of 29 Old 07-23-2012, 08:15 AM Thread Starter
blk83cj7+4
1983 CJ7
Ok, I got the dimmer switch out. The dash lights flashed on and off as I was removing it, good sign. Now on to disassemble the switch, maybe not. It doesn't look like I could get it back together if I did.......... The switch was caked with mud by the way........................................Okay, I cleaned up the switch and it works fine now. Now I have to figure why I don't have back-up lights.
blk83cj7+4 is offline
post #17 of 29 Old 07-23-2012, 02:37 PM
Crazyray2929
1981 CJ7
Check the switch on the tranny.
Crazyray2929 is offline
post #18 of 29 Old 07-23-2012, 07:38 PM
John Strenk
John Strenk's Avatar
1976 CJ5
And your fuse marked BU
John Strenk is offline
post #19 of 29 Old 09-03-2012, 06:17 PM
DENVAR03
john
every time i get ready to close up dash,and move on ,SOMETHING ELSE!!!!.i am checking my auto meter gauges,to make sure they are ok,and BAM!!
DENVAR03 is offline
post #20 of 29 Old 09-03-2012, 06:23 PM
DENVAR03
SORRY,hit the post button.i have power to my volt gauge,and a good ground,but it does not read any voltage with key in on pos.alsoi show full power,at the temp,and oil gauges,on the ing. poston gauge,but a dim light on the sender post.also when i go to wire,going to sender,it is dim also.what do you think is wrong.??? does engine have to be running??
thanks dennis
DENVAR03 is offline
post #21 of 29 Old 09-04-2012, 12:17 PM
John Strenk
1976 CJ5
If you have power to the volt gauge and a good ground the only problem could be a bad gauge.
The dim lights on the gauge is a problem. Dim is somewhat OK but should be flashing.
It's dim because it's on the lower part of the circuit tree were the voltage is less. I can get more into this but I have to get back to work.
It means your sending unit is running a lot of current through it turning it into heat.
post #22 of 29 Old 09-04-2012, 03:12 PM
DENVAR03
JOHN
thanks for getting back to me,the both gauges ,are new,auto meter,oil,and water.i will check ground again,and let you know.what about my volt gauge,power going in,but it is not reading any voltage with key on.
dennis
DENVAR03 is offline
post #23 of 29 Old 09-04-2012, 04:22 PM
John Strenk
1976 CJ5
Originally Posted by DENVAR03
JOHN
dennis
If the ground is good then it's got to be the gauge. Make sure the connections good.
post #24 of 29 Old 09-05-2012, 02:44 PM
DENVAR03
JOHN
i disconnected my volt gage,and put the stock one back in,and i get voltage,you were right bad gauge!!!.i called auto meter,and will ret.for a new one.my last problem before i ca close up dash,and move on,is still the 2 purple wires going to temp. sender,and oil sender.i am hot at each gauge,rechecked grounds fine,but i still get a solid dim light at sender wire at each end.i don't know what to do,if i close up dash,maybe i have to open again!!!!!do you think they will work,when engine is running,with that dim light???.
dennis
DENVAR03 is offline
post #25 of 29 Old 09-09-2012, 02:07 PM
DENVAR03
John
you mentioned,that a dim light ,at temp,and oil ,sender wire,might be ok,because i have auto meter gauges.do you think i could close up my dash,and install steering col,or should i check something else!!.i would like to move on in my restoration.
Thanks dennis
DENVAR03 is offline
post #26 of 29 Old 09-11-2012, 09:02 AM
DENVAR03
Can anyone tell me if a dim light,at sender wire,on temp,and oil gage is ok,using auto meter sport comp gauges.i do not get a flashing light ,just a dim solid light.
Thanks dennis
DENVAR03 is offline
post #27 of 29 Old 09-11-2012, 09:42 AM
John Strenk
1976 CJ5
Sorry about the delay, i usually don't get on on weekends.
I'm pretty sure the aftermarket gauges having a dim light is just fine.
post #28 of 29 Old 09-11-2012, 07:08 PM
DENVAR03
JOHN
THANK YOU SO MUCH,!!!!!.TIME TO MOVE ON TO GET HER RUNNING.
DENNIS:
DENVAR03 is offline
post #29 of 29 Old 09-14-2012, 09:17 AM
DENVAR03
hi
Does anyone know what the orange wire with connector on front harness,by dr. side marker lights is for?????
DENVAR03 is offline
electrical , gauges
Temp/Fuel Gauges adman02 Jeep CJ Forum 9 05-03-2010 02:11 AM
new gauges all work except temp? rodjr Jeep CJ Forum 6 11-30-2008 04:14 PM
Fuel and Temp Gauges Gart79CJ Jeep CJ Forum 4 08-17-2006 06:14 PM
fuel & temp. gauges guilloejeep Jeep CJ Forum 1 04-24-2006 09:56 PM
Fuel and temp gauges won't work... Radon Jeep CJ Forum 6 12-18-2002 07:59 AM
