Fuel and Temp Gauges Don't Work - JeepForum.com
post #1 of 29 Old 07-15-2012, 08:54 PM Thread Starter
blk83cj7+4
1983 CJ7
No back light for speedometer. No high-beam indicator light. Directional indicator lights DO work. Do oil pressure and battery gauges have backlights?
Where do I start troubleshooting?
blk83cj7+4 is offline
post #2 of 29 Old 07-15-2012, 08:58 PM
Trapshooter
One of our Moderators on the CJ forum is John Strenk. Do a search and you will find all the answers for your gauge issues. John is the man when it comes to fixing gauges problems.
Good Luck............
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 29 Old 07-16-2012, 12:04 AM
BagusJeep
1981 CJ7
As most of what you refer to are lights I would check the fuses, then check at the light switch that you are feeding voltage to dash lamps.
When you look up behind the gauge cluster you can see the wires and bulbs. Are they getting voltage?
Best tool is a test lamp and long leads. Hook one end up to battery -ve and start pprobing for voltage.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 29 Old 07-16-2012, 12:26 AM
Crazyray2929
1981 CJ7
When I had no lights I turned my dimmer switch up first...
Crazyray2929 is offline
post #5 of 29 Old 07-16-2012, 02:12 AM
John Strenk
John Strenk's Avatar
1976 CJ5
What about the lights for the controls on the dash like heater and vent. Do they light up or all all dash lights dead?
John Strenk is offline
post #6 of 29 Old 07-16-2012, 06:51 AM
CJ5COLORADO
I am having this same issue. I have installed mechanical temp, oil and volt guages.
CJ5COLORADO is offline
post #7 of 29 Old 07-16-2012, 08:54 PM Thread Starter
blk83cj7+4
1983 CJ7
Thanks everyone for the replies. I guess I must learn to use that voltage tester collecting dust over there. Where the heck is the dimmer switch? lol. This Jeep was missing a few things when I got it, like the fast idle assembly. So I have a new carb on order. The jeep supposedly sat for 6 years. There is no power in 4th or 5th gear, so I must avoid the interstates until I figure it out.
post #8 of 29 Old 07-16-2012, 08:57 PM Thread Starter
blk83cj7+4
1983 CJ7
Oh, and yes, all dash lights are out except for the turn signals and hazards.
post #9 of 29 Old 07-17-2012, 02:53 AM
John Strenk
1976 CJ5
Dimmer switch is on the headlight switch. Turn it one way or the other to brighten or dim your lights.
If you turn it in one direction you will feel a click and that should be full brightness. If the lights don't work then,
Time to get the test light out. And start testing fuses.
What happens is corrosion builds up on the wiper of the dimmer potentiometer and looses contacts' The windings have been known to fall out and short blowing fuses.
Short above
Corrosion and Loose windings could lead to shorts.
Maybe someone can confirm what direction is full brightness.
post #10 of 29 Old 07-17-2012, 06:00 AM Thread Starter
blk83cj7+4
1983 CJ7
Can the dimmer switch be restored?
post #11 of 29 Old 07-17-2012, 06:26 AM
John Strenk
1976 CJ5
I've never tried but probably some cleaning and some epoxy can but it back into shape.
Switches didn't use to cost to much.
post #12 of 29 Old 07-18-2012, 04:01 AM Thread Starter
blk83cj7+4
1983 CJ7
Thanks John, is there a special tool to remove the switch from the dash? It looks that way from the cab side.
post #13 of 29 Old 07-18-2012, 06:22 AM
John Strenk
1976 CJ5
FIrst pull the knob and rod off. There is a button on the bottom that you press in and you can slide it out all the way.
Then use a needle nose pliers to remove the nut and bezel
post #14 of 29 Old 07-18-2012, 07:43 AM
Truck633
GO ONE MORE!!
Truck633's Avatar
just a quick make sure you disconnect the battery, when you press the button and remove the rod, the lights come on, and will stay on until you unplug the harness..... Ask me how I know this!
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #15 of 29 Old 07-22-2012, 10:58 PM Thread Starter
blk83cj7+4
1983 CJ7
Thanks guys. They is no knob so I don't have to worry about that.
electrical , gauges
Temp/Fuel Gauges adman02 Jeep CJ Forum 9 05-03-2010 02:11 AM
new gauges all work except temp? rodjr Jeep CJ Forum 6 11-30-2008 04:14 PM
Fuel and Temp Gauges Gart79CJ Jeep CJ Forum 4 08-17-2006 06:14 PM
fuel & temp. gauges guilloejeep Jeep CJ Forum 1 04-24-2006 09:56 PM
Fuel and temp gauges won't work... Radon Jeep CJ Forum 6 12-18-2002 07:59 AM
