Fuel and Temp Gauges - JeepForum.com
post #1 of 5 Old 08-10-2006, 10:34 PM Thread Starter
Gart79CJ
The issue I've been having is that the Fuel and Temperature gauges are not working at all. I have a '79 CJ with '79 sending units on the engine and in the gas tank. The main gauge I think is from an 80's CJ (ebay purchase) and the engine is a '73 304 V8. I pulled a fresh wire from the sending unit to the gauge on the fuel side and there is continuity on the temperature gauge wire to sending unit. All gauges appear to have the proper wires on each gauge terminal compared to the wiring diagram but I still have no reaction from either gauge. Any ideas for what I can check for would be awesome. Thanks for all your help and considerations.
Gart79CJ is offline
post #2 of 5 Old 08-10-2006, 10:56 PM
mike360
I have been having the same problem you are on my 1981 cj7. Look at my post, and I found this page and it really helped a lot. http://users.adelphia.net/~john.stre...for_cj_gau.htm
mike360 is offline
post #3 of 5 Old 08-11-2006, 12:59 AM
johnny_d
I had a buddy who was having the same problem with his fuel gauge. Is the tank the original? If so, you might want to drop the tank and check the sending unit. His problem was that the float was rotted out, and not floating.. The actual sending unit was working fine, gauge too for that matter, but since the float wasn't floating it was always empty. Just a suggestion to check out.
~Johnny
johnny_d is offline
post #4 of 5 Old 08-11-2006, 06:06 AM
John Strenk
John Strenk's Avatar
1976 CJ5
That link didn't work. Try this one.
Quick check CJ Gauges
Or this one:
Basic Troubleshooting CJ Gauges
John Strenk is offline
post #5 of 5 Old 08-17-2006, 07:14 PM Thread Starter
Gart79CJ
Thanks guys. I'll take a look. The tank is new and so is the sending unit....I will try the links to see where they may take me.
Gart79CJ is offline
CJ5 Fuel/Temp gauges nickgbb Jeep CJ Forum 6 04-07-2008 01:56 PM
fuel & temp. gauges guilloejeep Jeep CJ Forum 4 04-26-2006 11:16 AM
fuel & temp. gauges guilloejeep Jeep CJ Forum 1 04-24-2006 10:56 PM
Fuel/Oil/Engine Temp. Gauges? mideerhunter Jeep CJ Forum 6 11-15-2005 08:15 AM
fuel and temp gauges also boydog40 Jeep CJ Forum 2 02-13-2005 09:59 PM
