fuel & temp. gauges - JeepForum.com
post #1 of 2 Old 04-24-2006, 08:23 PM Thread Starter
guilloejeep
Angry fuel & temp. gauges
i am having trouble getting my fuel and temp. gauges to work on my 85 cj7. i have bought replacements and installed them in my speedo. temp. sending unit and fuel sending unit are new. have checked all grounds. when i power up temp. gauge goes high and fuel gauge goes full. the original fuel gauge had three terminals on back, S,I,A. the replacement only has two S,I. could this be the problem? all dash lights working fine, volt and oil gauge working fine. have visited cj gauge troubleshooting site but found no solution. help
guilloejeep is offline
post #2 of 2 Old 04-24-2006, 09:56 PM
Geer_hed
Geer_hed's Avatar
Good luck with that 2 terminal replacement Fuel Gauge. You should probably be like this guy and send them back for better replacement gauges. I didn't realize that they made replacements with two terminals until very recently, and already I only hear bad about them.
Anyway, your description indicates the gauges are shorting to ground, the senders are out of spec, or the current in the circuit is out of range for the gauge design.
Search this forum, there are about a billion gauge threads, but I'd start with getting better replacement gauges.
85 CJ7 / 258 / T176 / Dana 30/ AMC 20
Geer_hed is offline
CJ5 Fuel/Temp gauges nickgbb Jeep CJ Forum 6 04-07-2008 12:56 PM
Fuel and Temp Gauges Gart79CJ Jeep CJ Forum 4 08-17-2006 06:14 PM
fuel & temp. gauges guilloejeep Jeep CJ Forum 4 04-26-2006 10:16 AM
fuel and temp gauges also boydog40 Jeep CJ Forum 2 02-13-2005 08:59 PM
Fuel and temp gauges won't work... Radon Jeep CJ Forum 6 12-18-2002 07:59 AM
