fuel tank vent problem - Page 3 - JeepForum.com
 1Likes
post #31 of 38 Old 09-20-2010, 07:59 PM
way_of_life
1978 CJ7
I really wish I would have had those diagrams months ago haha
if you do crazy crazy things with your jeep and need to remove all of that stuff its pretty esy to cap that off and avoid having the extra crap in the rear fender
°lllllll°
way_of_life is offline
post #32 of 38 Old 09-21-2010, 08:34 AM
SuperDave2112
1983 CJ7
Originally Posted by h2ojeep View Post
I had the "out of fuel" problem when it was not out. Worked for months to find it. Turned out to be many things and the older CJs are seeming to have the problem.
To avoid a lot of explanation here, I will relate you to another thread that covers most of it. Problem may not be what you think.
http://www.jeepforum.com/forum/f8/cj...-fuel-1101974/
That link pertains to a 78 CJ, yours is a little newer, so the lines may not be as old, but the other factors could be the problem.
There are some other threads that address the problem as well if you want to search it.
My rubber is all new. I had to drop and clean out the tank when I got it, as it had a rag for a gas cap, and sat that way for years. Lots of water! Thank God for plastic tanks! I took the carb apart, cleaned it out, and ran a boat tank to limp it home.
I'm gonna look for pinched lines today, if I get time, and try sucking on the line that the check valves are hooked up to.
Thanks all for the advice. On a side note, It hasn't happened since I took the valve out of the gas cap yesterday. I'm thinking check valves/line. It is worst after a lot of off road jostling. I bet the check valves are sticking.
SuperDave2112 is offline
post #33 of 38 Old 01-12-2011, 03:08 PM
BLOWNHOWARD
Originally Posted by SuperDave2112 View Post
Just went out and looked. My stuff doesn't look like the stuff in the picture. I have a black, plastic tank. Two lines, feed and return, to the sending unit, and two lines that "T" in to one, going to what I am guessing are check valves that are inserted to rubber grommets in the top of the tank.
Maybe the cheap gas with alcohol in it has eaten up my rubber pickup line inside the tank? It's less than a year old.
Does anybody have a picture of what this looks like?
100% bone stock 1985 CJ7
BLOWNHOWARD is offline
post #34 of 38 Old 02-05-2013, 04:47 PM
Jimww
Just recieved a rebuilt liquid check valve from "Belmar international"for $192.95 including shipping and a core return label.
Looks good so far. No web site, call Bob at 1-800-826-2272.
Super nice guy and prompt service.
Jimww is offline
post #35 of 38 Old 09-11-2016, 01:02 PM
rlewis75
1975 CJ5
Could this valve cause a nearly full tank of gas to run out at the engine? Mine did. When I used the auxiliary tank it ran fine, but ran out of gas at the engine when using the main until I topped off the main tank.
rlewis75 is offline
post #36 of 38 Old 09-11-2016, 04:04 PM
CSP
Waddya mean it ran out at the engine? It ran out of a hole somewhere near the engine or what?
And no, none of the fuel system parts mentioned would make it run out of fuel, whatever that means. Fuel is either consumed by the engine or is lost via a leak somewhere. If the engine isn't burning the fuel, find the leak and repair it.
CSP is offline
post #37 of 38 Old 09-11-2016, 04:42 PM
Makanak
1982 CJ7
Have you tested by running the engine with the gas cap on, but loose so that the tank is vented to atmosphere, as I suggested earlier today?
Makanak
The more I try to pursue the easy way out the more difficult it is to reach my goal.
Makanak is offline
post #38 of 38 Old 09-18-2016, 12:17 PM
rlewis75
1975 CJ5
Sorry I haven't replied back. Yes I did. It and it ran the same. How do I fix it since the check valve is no longer available? It runs fine until it gets to a certain level in the tank, then it starts to have issues. Thanks for all your help.
rlewis75 is offline
Bad TBI electronic fuel pump or problem with fuel tank? boomvader Jeep CJ Forum 5 01-18-2010 10:26 PM
Fuel Tank Vent... Exposed Jeep CJ Forum 2 11-10-2009 08:08 AM
Fuel tank vent hoses spill gas bluesman423 Jeep CJ Forum 2 08-01-2009 11:28 PM
Fuel Tank Vent cj71983 Jeep CJ Forum 2 07-12-2007 10:22 PM
Fuel Tank Vent line 4wwest Jeep CJ Forum 4 01-26-2004 06:15 AM
