fuel tank vent problem - JeepForum.com
 1Likes
post #1 of 38 Old 05-05-2009, 06:13 PM Thread Starter
armedsks
2009 JK Wrangler
My fuel tank has 2 vent tubes comming off of it on the drivers side. Currently the way it is they are tied off together by the PO. I notice on my buddys Cj his go to a black module, then go to the evap canister.
My black module is gone but my evap canister(un hooked) is still there. Im pretty sure the tubes need to go some to vent, right?? Or is it ok to leave them capped
When i fuel up my tank lets out some pressure, when i open the gas cap.
armedsks is offline
post #2 of 38 Old 05-05-2009, 06:17 PM
keith460
Jeep. There's Only One
keith460's Avatar
The two vent lines should go to the factory liquid check valve as pictured.
rlewis75 likes this.
keith460 is offline
post #3 of 38 Old 05-05-2009, 06:27 PM
fuzz401
1978 CJ7
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #4 of 38 Old 05-05-2009, 06:41 PM Thread Starter
armedsks
2009 JK Wrangler
ok thanks for the pics. Im missing the liquid check valve and rollover check valve. Only thing i have left is a capped off line going to the evap canister. Basicly all the emissions was hacked out. What would be the best way to do something with the 2 vent lines??
armedsks is offline
post #5 of 38 Old 05-06-2009, 09:55 AM
83cj8
1983 CJ8
Fuel lines
I don't have my jeep right now because I am overseas. If I remember right one of the vent lines should go to the evaporative cannister. You may want to look up which of the four ports (in the cannister) that line should run into. The second vent line should run to the "out" side of the fuel filter. Your fuel filter should have two ports on one side of it; one goes to the carb and the other to the vent on the gas tank. This lets the psi above the recommended 4psi (I think) run back into the gas tank so that line is not really a vent but a return line from the fuel filter.
Hope this help.
83cj8 is offline
post #6 of 38 Old 05-06-2009, 04:46 PM
bigirons79CJ5
1979 CJ5
My roll over check valve was a rusty hunk when I bought my jeep and was not hooked up and the canister up front was gone. I capped one of the tubes coming from the tank. The other tube I hooked a new piece of fuel hose to it, routed it up by the tail light and put a chevy fuel filter on it. According to legend: the fuel filter will let the tank vent properly and act as a check valve to prevent water from entering and fuel from sloshing out.
79 CJ5 4" Skyjacker
35" Dunlop MT's, 9000lb Warn
304 built with Edelbrock cam,valve springs,timing set,intake,Holley truck avenger carb, DUI ignition, fenderwell headers w/Supertrapps, Twin Sticked D20
FOR MORE PICTURES, CHECK OUT MY PHOTOBUCKET
bigirons79CJ5 is offline
post #7 of 38 Old 05-06-2009, 07:44 PM Thread Starter
armedsks
2009 JK Wrangler
ok thanks i will try that.... easy enough to find a fuel filter!!
armedsks is offline
post #8 of 38 Old 05-06-2009, 07:50 PM
thantos858
1974 CJ5
Just buy the check valves they do more than just stop fuel from sloshing out. A fuel filter will let it all run out when you roll it. I know there was a post on here not to long ago about the same subject.
thantos858 is offline
post #9 of 38 Old 06-10-2009, 08:11 AM
carter262
1982 CJ7
Keith460
Where did you buy the rollover check valve and liquid check valve? I want to replace mine on an 82 CJ7 but am having trouble finding them.
Carter262
carter262 is offline
post #10 of 38 Old 06-10-2009, 02:34 PM
keith460
keith460's Avatar
The rollover check valve can be found here, if still available: http://www.delorean.com/store/p-6703...ver-valve.aspx
Don't know where you can get a liquid check valve as the one I have is my original from the factory.
1984 CJ-7 Renegade
keith460 is offline
post #11 of 38 Old 06-10-2009, 05:09 PM
carter262
1982 CJ7
Thanks,
Do you know if the liquid check valves go bad. I am redoing my 82' CJ7 and figured I would replace it since it is so old but can not find one. I have the original jeep part number but the dealership said that is is discontinued item.
post #12 of 38 Old 06-10-2009, 05:17 PM
carter262
1982 CJ7
Keith460 one more question.
What is this item and where does it go? Mine is cut off. I circled it in yellow on the picture.
post #13 of 38 Old 06-10-2009, 05:34 PM
keith460
keith460's Avatar
You can separate the Check Valve by removing the top portion and clean and inspect to see if it needs any work. They usually do not go bad unless the plastic is broken or modified in some way.
The item circled is the rear brake hose in it's bracket, connected to the rear brake line.
1984 CJ-7 Renegade
keith460 is offline
post #14 of 38 Old 06-11-2009, 11:25 AM
Stan99
1978 CJ7
Sorry to high jack but do you need the roll over valve? Mine didnt have one to start with, it only had the check valve.
1978 Jeep Cj7 Soa, Shackle Reversle, 36x13.5x15 Irocks, 4.5 Stroker MPI, Dana 300 twin Sticked, 4.88's
Stan99 is offline
post #15 of 38 Old 06-11-2009, 12:26 PM
jfwireless
1976 CJ7
Stan99:
My 1976 CJ7 did not come with a factory roll over valve either, just check valve and the factory manual confirms this. However I think it is a good idea to add it just in case you do roll over, you do not want fuel spilling all over you after a wreck.
The roll over valve was added sometime after 1976.
Jim
jfwireless is offline
Bad TBI electronic fuel pump or problem with fuel tank? boomvader Jeep CJ Forum 5 01-18-2010 10:26 PM
Fuel Tank Vent... Exposed Jeep CJ Forum 2 11-10-2009 08:08 AM
Fuel tank vent hoses spill gas bluesman423 Jeep CJ Forum 2 08-01-2009 11:28 PM
Fuel Tank Vent cj71983 Jeep CJ Forum 2 07-12-2007 10:22 PM
Fuel Tank Vent line 4wwest Jeep CJ Forum 4 01-26-2004 06:15 AM
