Fuel Tank Questions: Sending unit, and random hole - Page 2 - JeepForum.com
post #16 of 25 Old 12-02-2013, 08:37 PM Thread Starter
Gigemags05
1980 CJ7
I measured the resistance and I was getting around 77 and 10-12 it was bouncing around so I'm not sure I was getting an accurate reading.
Also, anyone have a part number for the fuel sock? Will I need a new gasket and lock ring as well?
Gigemags05 is offline
post #17 of 25 Old 12-03-2013, 03:40 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Was it 10 ohms full and 77 ohms empty? If so then this looks like a much better build that others I've seen.
Any idea who makes it? any numbers on the thing? I thought I saw a number on the wiper part.
How long is the pickup tube compared to your old one?
G, H, and I are probably what you need.
http://www.4wd.com/hardparts/HP_PartList.aspx?hpDID=264
John Strenk is offline
post #18 of 25 Old 12-03-2013, 08:08 AM
tdcanada
1973 CJ5
If you want you can take the sending unit up to the cab, and hook it to the gauge and move the arm, to see if it works properly. If you are missing parts and still unsure of it, you can buy the entire kit with gasket, locking ring, and filter for $40 from a number of places. I just dropped my tank and replaced the sending unit, all the fuel and vent lines and new wiring. I ran a new home run to the gauge and ran the ground wire out and anchored it to ground with a lug. I also cleaned and painted my tank with spray on bed liner.
tdcanada is offline
post #19 of 25 Old 12-03-2013, 12:15 PM Thread Starter
Gigemags05
1980 CJ7
I don't know what brand it is. I googled the number on it and got nothing. The number is: Y2lC-SP18
Also, the fuel sock/filter in the link above is for the 20 gallon tank. Would that also work for my 15 gallon tank, or do I need to find a different part? I am having a hard time finding one.
I actually don't have the old one or the tank at my house right now, so I cannot compare the two. I am working on it at a buddy's place. I was just rummaging through the box of parts that the OP gave me and remembered he'd mentioned that he had a new sending unit.
post #20 of 25 Old 12-03-2013, 02:05 PM Thread Starter
Gigemags05
1980 CJ7
This fuel sock is wearing me out. I can't find one that is for a 15 gallon tank.
I have a 4.0 w. F.I. so I run an in line electric pump. Would it be okay to use an inline filter after the sending unit but before the pump and not have a fuel sock on the pick up tube? If that'd work, what would be the best way to lengthen the pick up tube?
post #21 of 25 Old 12-03-2013, 02:44 PM
tdcanada
1973 CJ5
Ive heard of people putting a length of fuel line on the end and securing with a hose clamp, but I would worry about that picking up gunk that builds up in the bottom of the tank and possibly getting clogged. I know you want to save that sending unit, but it is a pain int the a@# to drop that tank. I tend to try and save and salvage some parts, but those that can strand me out on the road or trail or damage more expensive parts (Fuel pumps / injectors) I have learned over the years to belly up and get the correct parts. Im not a a quadratec salesman, but as I mentioned earlier, I just purchased the entire unit for $40, it had everything you need to put your tank back the way it is supposed to be.
tdcanada is offline
post #22 of 25 Old 12-03-2013, 02:51 PM Thread Starter
Gigemags05
1980 CJ7
I have a brand new sending unit to put in. I am not reusing the old one. I just need the filter. There has to be a better way than to essentially spend $40 just for a filter.
post #23 of 25 Old 12-03-2013, 02:55 PM Thread Starter
Gigemags05
1980 CJ7
never mind. I was able to find one.
http://www.jeep4x4center.com/filter-...9-3230376.html
post #24 of 25 Old 12-03-2013, 03:18 PM
tdcanada
1973 CJ5
Good, I think they have the rubber gasket and locking ring also.
tdcanada is offline
post #25 of 25 Old 12-03-2013, 10:45 PM Thread Starter
Gigemags05
1980 CJ7
Yes they do. I was able to pick those up for real cheap too.
Also got new filler and vent hoses while I'm at it. Replaced the rollover valve, cleaned the lcv, and replaced the charcoal canister last month. I should be good on the fuel end of things.
