Fuel Tank Questions: Sending unit, and random hole - JeepForum.com
post #1 of 25 Old 12-01-2013, 08:01 PM Thread Starter
Gigemags05
1980 CJ7
I'm replacing the bed portion of my jeep and decided to drop the tank while I'm at it and replace the fuel sending unit.
The PO of the jeep had this fuel sending unit that he was going to put into the jeep but never got around to it. It looks different than the pictures of sending units I've seen online. Will it still work even though the line fittings are pointing differently? Are other parts the same?
Also, when removing the tank, we noticed a perfectly round hole in the top of the tank. Directly under where the seat belt is mounted on the bed of the jeep. Surely that isn't supposed to be there, right? If it isn't, any ideas of how to properly plug it?
Anything else I should change while the tank is on the ground?
Gigemags05 is offline
post #2 of 25 Old 12-01-2013, 08:03 PM Thread Starter
Gigemags05
1980 CJ7
One other question... am I correct in assuming that I need to put a filter on the pick up tube?
post #3 of 25 Old 12-02-2013, 01:04 AM
John Strenk
John Strenk's Avatar
1976 CJ5
If you have an ohm meter, I'd check the resistance first. Make sure it's compatible with a CJ fuel sending unit.
The hole looks like someone drilled through the floor of the CJ and hit the tank. Not sure how to fix it, Maybe glue a metal slug over it with a fuel resistant epoxy?
The pick up filter extends the pickup of the tank so yeah, it's needed.
John Strenk is offline
post #4 of 25 Old 12-02-2013, 01:38 AM
BagusJeep
1981 CJ7
As John said the thing will fit but it is the reading it will give you that matters. The orientation of the tubes wil not matter at all.
The pick up filter does extend it but I seem to be blessed with Jeeps where POs have all opted for a short length of fuel hose on the end zip tied on. They reach to the bottom all right but a lot of gunge gets in.
That is not a factory hole but is certainly drilled.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 25 Old 12-02-2013, 06:27 AM
ScroungerLee
I would seal that hole with http://www.jbweld.com/product/j-b-waterweld/ which can be used for fuel tanks. I have used it for this with great success. It can even be used to plug a hole while it is leaking, although I haven't tried that.
ScroungerLee is offline
post #6 of 25 Old 12-02-2013, 09:29 AM Thread Starter
Gigemags05
1980 CJ7
Does anyone know what resistence it should read?
I have an OHM meter.
post #7 of 25 Old 12-02-2013, 09:38 AM
tdcanada
1973 CJ5
0 ohms to 73 ohms I thing for the CJ fuel gauge...0 being full and 73 being empty
tdcanada is offline
post #8 of 25 Old 12-02-2013, 09:41 AM
tdcanada
1973 CJ5
I might go with a sheet metal screw the size for the hole with a rubber washer
tdcanada is offline
post #9 of 25 Old 12-02-2013, 09:52 AM Thread Starter
Gigemags05
1980 CJ7
I know this is incredibly remedial, but how exactly do I test that?
I've googled it and it didn't come up with a whole lot. I've also tried searching John Strenk's posts but haven't come up with much.
post #10 of 25 Old 12-02-2013, 10:03 AM
John Strenk
1976 CJ5
10 Ohms full
73 Ohms Empty.
Take your ohm meter and put one lead on the screw terminal and clip your other lead to the case or tube and move the float up and down.
post #11 of 25 Old 12-02-2013, 10:07 AM Thread Starter
Gigemags05
1980 CJ7
alright, when you say case or tube do you mean the pick up tube?
I'm sorry for my ignorance.
post #12 of 25 Old 12-02-2013, 10:16 AM
John Strenk
1976 CJ5
No problem.
Mounting flange, pick up tube, outlet fitting anything metal.
That black wire riveted to the back or the terminal spot welded to the top would be the best place.
post #13 of 25 Old 12-02-2013, 10:18 AM Thread Starter
Gigemags05
1980 CJ7
AWESOME! Now that's some direction I can follow.
Thank you very much. Hopefully this will save me $50.
post #14 of 25 Old 12-02-2013, 10:42 AM
John Strenk
1976 CJ5
Post your results if you will.
Just to let us know how that style works.
post #15 of 25 Old 12-02-2013, 10:57 AM Thread Starter
Gigemags05
1980 CJ7
will do.
