Fuel Tank Install Tips - JeepForum.com
post #1 of 5 Old 09-08-2005, 07:13 PM Thread Starter
fireman77
any tips on installing a new tank on a 1977 cj5. also, my fuel gauge has never worked, can i wire the new sending unit directly to a new gauge, will that work at all?
any help, would help
ROLL TIDE
fireman77 is offline
post #2 of 5 Old 09-08-2005, 08:17 PM
jeepduo
1978 CJ7
I am also to the point of putting my tank back on. any pics of a 78 CJ7?
1978 CJ7, Driving, but never finished
jeepduo is offline
post #3 of 5 Old 09-09-2005, 03:47 AM
Thomas.Pedersen
Thomas.Pedersen is offline
post #4 of 5 Old 09-09-2005, 08:48 AM
Geer_hed
Geer_hed's Avatar
Piece of cake. This thread has some good advice, but it's really pretty straightforward. That's a good writeup BTW...
You definitely want a new sending unit with a new collection tube filter while you've already got the tank out. The new sending unit won't necessarily correct the gauge issue. HOWEVER, do not hook up current to the sending unit without hooking up the Ground wire first! You will cook your sending unit and that will just suck. The gauge issue is another thread for another day, right?
Best advice one could really offer here is get that thing as close to empty as possible before attempting to remove it and use a jack so it can be lowered a little bit at a time, some of those hoses will hang up and you can't get to them immediately. Otherwise, just put it back the way ya found it, ya know?
85 CJ7 / 258 / T176 / Dana 30/ AMC 20
Geer_hed is offline
post #5 of 5 Old 09-09-2005, 09:20 AM
asoude1
i dropped my fuel tank about a month ago. it is very easy, the only part that was remotely hard was reconnecting the hose to the filler neck. and definately change out your sending unit. now the gauge issue. my gauge on my spedo never worked either. the guy that had it before me put a new gauge in it. but he didnt know what he was doing. all you need is a gauge that has 3 prongs on the back. one should be for positive, the other for ground, and the third for the wire that comes from the sending unit. if you want to check to see if your original gauge works though there is a really easy way. connect the positive to a 12v source and connect both the ground and the sending unit wire to ground. when you do this the gauge should move towards full. if that happens then the gauge still works.
if you have anymore questions just pm me.
asoude1 is offline
Bad TBI electronic fuel pump or problem with fuel tank? boomvader Jeep CJ Forum 5 01-18-2010 10:26 PM
Tips on dropping fuel tank skclark Jeep CJ Forum 33 01-09-2010 06:21 PM
Tank is full, fuel gauge reads Half tank!?! martyweir Jeep CJ Forum 10 09-25-2008 06:55 AM
Installing Fuel Tank and Fuel Lines? How Hard? JeepFan07 Jeep CJ Forum 6 01-10-2008 06:49 PM
swapped fuel tank and no fuel at carb 8679cjs Jeep CJ Forum 6 12-05-2005 10:17 PM
