Fuel Tank - JeepForum.com
post #1 of 3 Old 08-07-2009, 11:08 AM Thread Starter
mtnsammy
1990 XJ Cherokee
Fuel Tank
I dropped my tank after an evap test for smogg. Fuel was gushing out from the top. It passed the first time but I went off road playing on the rocks and something went pop.
Short version small tube on sending unit broke off and all the hoses look like sponges. I am suprised I could hold any fuel at all. Inside the tank is the usual scales and rust. POR 15 will repair the stock tank at about $50 new sending unit $30.
Question?? Should I replace the tank with 21 gallon aftermarket or 15 gallon? $119 for steel $339 for poly-15 still looking for 21 gallon poly.
This rig is great on the rocks but I am only lifted 2-3 inches now with 31 inch tires.
mtnsammy is offline
post #2 of 3 Old 08-07-2009, 11:31 AM
string
1982 CJ7
I replaceed my stock 15 Gal steel tank, with poly 21 Gal, almost two years ago, I have found that I have to think less about my remaining fuel since. so that means longer trips!!
last year I repalcesd my fuel tank skidplate as I hit it hard one time and found that rust was slowly eating it. I sitll havent had any problems with the poly tank.
string is offline
post #3 of 3 Old 08-07-2009, 02:13 PM
Rob55
I replaced my 15 with the OEM 21 gallon tank (not the aftermarket 21 gallon tank) to keep my ground clearance. The 21 gallon aftermarket hangs down about 4 inches lower than the 15 gallon. I also picked up a 4x Doctor skid plate for it that is incredible. The 21 OEM units are a bit harder to find but they are out there. (They fill the entire area between the leaf springs/fram rails rather than hang down further to get the capacity). Hope this helps. Either way poly is a the best way to go, if you have a good skid plate.
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back....
Rob55 is offline
Bad TBI electronic fuel pump or problem with fuel tank? boomvader Jeep CJ Forum 5 01-18-2010 11:26 PM
Fuel float next to fuel tank migolito Jeep CJ Forum 4 01-10-2010 09:36 AM
Tank is full, fuel gauge reads Half tank!?! martyweir Jeep CJ Forum 10 09-25-2008 07:55 AM
Installing Fuel Tank and Fuel Lines? How Hard? JeepFan07 Jeep CJ Forum 6 01-10-2008 07:49 PM
swapped fuel tank and no fuel at carb 8679cjs Jeep CJ Forum 6 12-05-2005 11:17 PM
