Fuel tank 20gallon CJ7 - JeepForum.com
 1Likes
post #1 of 42 Old 10-07-2017, 12:27 PM Thread Starter
Nick4320
So I have the 20 gallon gas tank on my 85 CJ7, when I get a fuel tank of gas the vac can is sucking up gas and leaking. So I thought it would be the liquid check valves on top. Replaced them still having the issue.
I noticed when getting gas this time my gauge showed the tank being about a 1/4 past full, not quite sure if this indicated anything.
I know I can't get a new replacement tank unless I mod it for the 15 gallon setup, not looking to do that.
Nick4320 is offline
post #2 of 42 Old 10-07-2017, 01:06 PM
LumpyGrits
Cj
Nut'n wrong with the tank.
The sender with the fuel lines needs inspection.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 42 Old 10-07-2017, 01:34 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Nick,
There's a filter in the bottom of the vapor canister. When that filter gets clogged with mud and road grime, which happens frequently, the vacuum source for the canister will suck fuel from the tank instead of air thru the filter as it should.
You can replace that filter, but the old one may be kinda difficult to remove from the canister. I believe they still sell replacement filters. If not, you can cut a Chore Boy scrubber pad to size, and stick it in there. Of course, a new vapor canister is also an option to consider, especially if yours is the original.
Good luck,
Matt
Matt1981CJ7 is offline
post #4 of 42 Old 10-07-2017, 03:38 PM Thread Starter
Nick4320
Matt, I checked the vac can, there's not filter on the bottom, unless it's sealed inside.
I believe its the original. I'm looking at getting a me can right now but can't seem to find an OEM one. I was hoping to find one maybe better then OEM. Any suggestions?
Nick4320 is offline
post #5 of 42 Old 10-07-2017, 03:53 PM
Matt1981CJ7
1981 CJ7
Yes, the filter is inside. It should look like the canister on the right in the pic below, if it's original.
New OEM style canisters have become a unicorn to find, but you use this Delorean canister as a suitable replacement. It should even fit in the factory bracket.
https://store.delorean.com/p-6675-carbon-canister.aspx
Matt
post #6 of 42 Old 10-07-2017, 03:57 PM Thread Starter
Nick4320
Yeah it looks like the one on the right but with out the cotton piece.
As for the new one, it looks like it only has 3 ports, the OEM has 4 does one not get connected?
Nick4320 is offline
post #7 of 42 Old 10-07-2017, 04:02 PM
Matt1981CJ7
1981 CJ7
The canister in your pic looks like it has a filter to me. Perhaps is so caked with mud, it's difficult to tell.
Anyway, the Delorean canister is a 4 port. They are just in a different configuration than the Jeep version. The ports will all be labeled for you.
Matt
post #8 of 42 Old 10-07-2017, 04:15 PM Thread Starter
Nick4320
Awesome thanks Matt, think you just saved me a whole mess of trouble
Nick4320 is offline
post #9 of 42 Old 10-07-2017, 05:05 PM
shadoow
I bought one of the delorean canisters from a link Matt posted awhile back. The delorean canister has 4 ports as Matt said and they are labeled. I had to get some tubing as what was on my jeep wasn't the right size so good time to get all new hoses for the hookup. Also, the delorean canister is a little fatter than the stock one, but it will still fit into the stock circular clamp. Pretty easy job to change over and I've had no problems with it.
shadoow is offline
post #10 of 42 Old 10-07-2017, 05:43 PM Thread Starter
Nick4320
Just ordered that can
The can I have on there, the only way to remove the filter would be to cut into it. So I'm guessing that's an internal filter which is probably clogged and causing my issues
Nick4320 is offline
post #11 of 42 Old 10-07-2017, 05:52 PM
Matt1981CJ7
1981 CJ7
Yeah, the canister filter isn't an easy replacement. It can be done, but... hence my warning earlier.
It's probably best that you are replacing the whole canister.
Keep us updated.
Matt
post #12 of 42 Old 10-12-2017, 05:27 PM Thread Starter
Nick4320
Got the vac can today. Installed it after work. Drive it around and it seemed fine no noticeable issues. Tomorrow I'm going to take her to the gas station and fill her up. Fingers crossed all goes well and no leaking.
On a side note, here are the pics of the can. The breather is still on the bottom.
20171012_174234_1507850372766.jpg   20171012_174213_1507850791337.jpg   20171012_174225_1507850812035.jpg
Nick4320 is offline
post #13 of 42 Old 10-13-2017, 01:27 AM
Matt1981CJ7
1981 CJ7
Well, did the new canister solve the fuel siphoning problem?
Matt
post #14 of 42 Old 10-13-2017, 04:46 PM Thread Starter
Nick4320
Filled up, no siphoning or gas anywhere it shouldn't be. New can works perfectly
Nick4320 is offline
post #15 of 42 Old 10-14-2017, 11:41 AM
Matt1981CJ7
1981 CJ7
That's great!
Glad you didn't drop the tank, unnecessarily.
Matt
LumpyGrits likes this.
