fuel system?? - JeepForum.com
post #1 of 6 Old 05-19-2003, 02:27 PM Thread Starter
edwardsd
Question fuel system??
I am replacing my gas tank in a 78 cj a stock 15 gals. I ran across the liquid check valve and the roll over valve I think. Both are pretty much rottened away. Should I just cap them off or replace them? If replacing them is your answer , were can I get them? I looked on several different web sites and haven't seem any. Help!
edwardsd is offline
post #2 of 6 Old 05-19-2003, 03:40 PM
fuzz401
1978 CJ7
they were there to shut off the gas flow in case of a roll over the tank was vented through them
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 6 Old 05-20-2003, 12:16 PM
fuzz401
1978 CJ7
the roller over valve is still avable from the dealer the liquid valve is not any more
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #4 of 6 Old 05-20-2003, 01:32 PM Thread Starter
edwardsd
alright . then here is my second question. i have two fuel vent lines coming off the tank that go to the top of the liquid valve. then one line goes to the roll over valve and to the front of the cj.can i plug one of the two fuel vent lines? if so which one do i plug ? and then just bypass the liquid valve and go to the roll over valve? or should i try to find a liquid valve off of another cj or even may a full size jeep?thank for the information!
edwardsd is offline
post #5 of 6 Old 05-20-2003, 03:51 PM
fuzz401
1978 CJ7
the 2 vent hoses across from the filler hose went to the liquid valve then to the roll over valve then to the charcoal canster by the engine which vented the gas tank do not plug that hose or the gas tank could suck in block off the one vent hose and run it to the roll over valve then to the charcoal can most of the liquid valves were plastic and the roll over valves were steel and the fsj had a compleatly diff set up on them as far as i know it does not matter what hose is blocked off i might have a used liquid valve laying around went with new when i started redueing my jeep many years ago
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #6 of 6 Old 05-20-2003, 04:14 PM Thread Starter
edwardsd
one day when you're in your shop/ garage and run across it,let me know. if it isn't rotting away.thanks
edwardsd is offline
74 Cj5 Fuel System BEERKAN Jeep CJ Forum 4 01-02-2009 09:55 PM
Fuel system questions Scott 77CJ Jeep CJ Forum 3 07-17-2007 01:25 PM
fuel system question Boycejer Jeep CJ Forum 7 01-09-2007 07:38 PM
Fuel System Problems 18minutes Jeep CJ Forum 3 04-20-2004 11:34 AM
1984 CJ Fuel System bhaller Jeep CJ Forum 2 03-26-2004 08:38 AM
