Fuel Supply cutting out - Page 2 - JeepForum.com
post #16 of 21 Old 08-21-2011, 06:11 PM Thread Starter
crazy8x4o5
1978 CJ7
back to the filter issue, i just have a single inline filter right before the carb. Just took this pic to give a better idea
crazy8x4o5 is offline
post #17 of 21 Old 08-21-2011, 10:45 PM
SBpunk
I had the exact same problem. This is how I troubleshot it. Read the last post. Good luck
http://www.jeepforum.com/forum/f8/fu...-hope-1250233/
SBpunk is offline
post #18 of 21 Old 08-23-2011, 06:36 PM Thread Starter
crazy8x4o5
1978 CJ7
I'm thinking my fuel tank is fuel of crud. before I got the jeep the PO let it sit for about 5 years. once I get a chance to drop the tank and verify what is the best way to flush the tank out?
post #19 of 21 Old 08-23-2011, 10:22 PM
afgd1
older cjs and engines dont like additives, esp ethanol, take off top fuel line crank engine, see if fuel comes out, ck if coming out past fuel filter , now big thing if carb has filter in line check it too, cjs need to have all carbs tuned, and clean, others parts to this problem could be the air lines i had to change out charcoal canister and most all air lines ck for cracks even the smallest crack can screw with carb i also put regulator in line i think fuel line runs 5-7 psi with carter carb its not so critical other carbs seem to need it hope this helped i also have to clean carb about every 2500 miles just cus of fuel we have here colorado, a good carb cleaner seems to work good change filter too aleast 2 times a year
afgd1 is offline
post #20 of 21 Old 08-24-2011, 02:08 PM
Mudr83
2016 JK Wrangler
check your fuel lines where they change from rubber to steel ( that connection is above the fuel tank ). I had the same symptons that you explained and found that i was sucking in air at that connection. Quick fix was putting 2 small hose clamps on it. 2 years and the problem has not came back.
Mudr83 is offline
post #21 of 21 Old 09-18-2011, 01:01 PM Thread Starter
crazy8x4o5
1978 CJ7
finally found time to drop the tank. the outlet line was dry rotted. the inside of the tank was spotless.
Lifetime Supply of Relays $50 Exposed Jeep CJ Forum 18 02-08-2010 02:57 PM
Air Supply--not just a band in a jeep Collard Green Jeep CJ Forum 7 05-24-2007 03:05 PM
Using Por 15/Supply elks96 Jeep CJ Forum 8 05-18-2007 10:31 AM
brake supply question gumby Jeep CJ Forum 6 12-22-2006 07:51 PM
How big of a fuel supply line for a 360 HIPPER Jeep CJ Forum 3 04-11-2004 09:57 PM
