Fuel Starviation part 2 - JeepForum.com
post #1 of 3 Old 11-30-2008, 09:51 PM Thread Starter
h2ojeep
1978 CJ7
I am at a loss as to the problem http: I got this jeep in April and this has happened every time to the best of memory, When my tanks get about half empty, I get starved for fuel. The problem has been complicated by vapor lock through the summer, but now, heat is not a factor. What have I done to solve? New Gas tank (went from 15 gal to 25 gal) and with the old tank, the problem occurred when about 8 gal low, and with the new tank, about 13 gal, I have also put front to back new fuel line, put in a elec fuel pump, added an un- restricted line to vent the tank (to eliminate a vacuum on the tank if there was any) , new mechanical fuel pump and new fuel filter. Reading other threads on this forum, I discovered I may have the fuel filter in wrong, and turned it where the return line was on the highest radius and the return line coming out and up in at the highest position (I really though I had it). Today, about half low, no fuel to the carb, bowl empty, filled it up (13 gals) (primed the carb) and I am good to go.
What could it be?
h2ojeep is offline
post #2 of 3 Old 12-01-2008, 02:36 AM
OldSailor
1977 CJ7
When you replaced the fuel tank, did you replace the float in the tank?
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
post #3 of 3 Old 12-01-2008, 08:15 AM Thread Starter
h2ojeep
1978 CJ7
Question on replacing float in new tank. Yes, the new larger tank was a complete kit, and included the dip tube and float already installed (also included hardware to extend the skid plate). I examined the dip tube through the main nozzle hole by shining a light down the nozzle vent line, and could see that the dip tube ran near the bottom of the tank (was trying to see the float too, but could not get the correct angle to see it) Not that it matters, but the fuel gauge indicates near empty when I am 13 gal low (on a 25 gal tank)
h2ojeep is offline
Fuel Starviation h2ojeep Jeep CJ Forum 4 10-21-2008 12:24 PM
part # for 1983 cj5 21 gal. plastic fuel sender atesrn Jeep CJ Forum 1 05-12-2008 12:55 PM
Where can I get this part? Fuel Related CJ83 Jeep CJ Forum 5 01-06-2008 09:18 AM
Fuel tank skid plate part ? BIGM Jeep CJ Forum 1 04-04-2005 03:31 PM
Fuel Part...Its hard to get... nmjeeper Jeep CJ Forum 1 09-29-2004 04:19 PM
