Fuel/Starting Problem - JeepForum.com
post #1 of 11 Old 09-29-2013, 08:47 AM Thread Starter
SandersCJ7
I have a 78 CJ7 Golden Eagle with the 304 that I bought from a man about a year ago. He had put a new battery, distributor, plugs, wires, filters etc on it. I drove it for a few months then had the jeep body work done last winter. Got it out of the body shop and drove it a few weeks. I had recently had the timing set but it was still having problems missing. I assumed trash in the carb or fuel tank as it had sat a while. While driving down a back road about 35 it spit and sputtered and quit. I could not get it to restart and while cranking on it it would puff vapors from the carb and on certain rotations the motor would lock down until I let it sit a moment. When loading it on the trailer liquid fuel (I assume) flowed out of the exhaust. I'm assuming a quart at most. I have let it sit up a while and now have started piddling with it again. The plugs wires are getting fire (the two I checked) and it sputtered once but will not start. Any suggestions on where to start? I recently bought an Auto Parts store so Im ready to get some things replaced and get it up and running for the fall.
SandersCJ7 is offline
post #2 of 11 Old 09-29-2013, 08:52 AM Thread Starter
SandersCJ7
Carb
Forgot to mention it appears to have the Motorcraft 2105 carb.
post #3 of 11 Old 09-30-2013, 12:42 AM
BagusJeep
1981 CJ7
A quart of fuel would be a LOT.
Could it have been water???? If water, did it look like coolant or rain water?
It could be that you have a major water leak. Have you checked the collant level?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 11 Old 09-30-2013, 04:29 AM
LeePrather
1978 CJ5
Have you checked to make sure your fuel pump is getting fuel? Do you have a fuel filter with 2 hoses coming out, 1 going to carb and 1 to the gas tank? If so, do you have the line going to the tank on top of the line going to the carb?
I would also check the plug wires to make sure they aren't accidentally crossed and they are all tight
LeePrather is offline
post #5 of 11 Old 09-30-2013, 05:03 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
1. Fuel - Confirm fuel is getting to the carb.
2. Air - Confirm the choke is functioning properly.
3. Spark - Confirm you have spark at the plugs while cranking.
Matt
Matt1981CJ7 is online now
post #6 of 11 Old 09-30-2013, 05:48 AM Thread Starter
SandersCJ7
I my memory serves I went back and looked and it was defiantly fuel....however, I was having some problems with it getting hot before I parked it and looking in the radiator yesterday it appears I have lost some coolant....I'll examine it more today....
I pulled the fuel filter, which does have three lines, and it was bone dry.
post #7 of 11 Old 09-30-2013, 06:24 AM
82JeepCJ7
1982 CJ7
Pull the oil dip stick and look for signs of fuel or water. Pull the radiator cap off and check for oil in the coolant.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #8 of 11 Old 09-30-2013, 06:33 AM
roadhog304
1973 CJ5
Pull the fuel line off of the carb and have someone crank it over while you watch to see if you have a good stream of fuel coming from the fuel pump.
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline
post #9 of 11 Old 10-02-2013, 07:40 PM Thread Starter
SandersCJ7
Well I didn't see any water in the oil, or oil in the radiator....battery is low so I didn't get a good crank on it to check the fuel pump....this weekend I'm gonna drain the oil pan and charge the battery....I should no more then.
post #10 of 11 Old 10-13-2013, 11:40 AM Thread Starter
SandersCJ7
Well I pulled a plug and it appears it has water in the cylinder....plug is rusted....
post #11 of 11 Old 10-13-2013, 01:15 PM
Matt1981CJ7
1981 CJ7
Bummer...sorry to hear that.
Matt
