Fuel sender connection, push-on or bolt on fitting? - JeepForum.com
post #1 of 4 Old 05-17-2011, 05:52 AM Thread Starter
243
1978 FSJ Cherokee
I am pretty sure I have the original push on fitting for my fuel sending unit but I think a brass washers, a nylon lock nut and dialetic grease would be more secure.
If you have changed the sending unit, did you use the stock connector or improvise?
Dave's 78 Build
243 is offline
post #2 of 4 Old 05-17-2011, 05:58 AM
gojeepin
1983 CJ7
I sprayed contact cleaner in the old connector and pressed it on. It works fine.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 4 Old 05-17-2011, 10:34 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I think mine has an eyelet crimped/soldered/heatshrinked on the wire, and a S.S nut and lock washer with a glob of dielectric grease on it before and after it was assembled.. I had also done the same with a piece of wire I soldered the spade connector to the tab for the new sender's ground, which I ran up to a good ground connection near the battery.
Rick
Cutlass327 is offline
post #4 of 4 Old 05-17-2011, 01:20 PM
JeepHammer
Running On Empty...
1973 CJ5
There is usually a push on type spade connector on the sender, that if for a ground wire.
If you are smart, you will solder that spade connector to the tab, heat shrink the connection.
I usually solder the ground down, heat shrink the connection, then put a connector out from under the top of the tank, over by the roll over valve so if I need to drop the tank in the future, I just unplug the ground connection and let the tank drop.
The senders I've worked with usually have a ring terminal for the sending unit 'Power' side.
Same thing here, with a short length of wire you can attach to the connector for the sending unit, then have a second connector out from the tank.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
Fuel Sender help please... breakthru Jeep CJ Forum 16 02-04-2011 10:25 AM
Fuel Sender Help. Eagle2 Jeep CJ Forum 24 06-04-2009 08:42 PM
Need help ID-ing this Fuel sender BioTex Jeep CJ Forum 1 04-07-2009 06:41 PM
CJ fuel sender question.... gojeepgo Jeep CJ Forum 6 02-12-2009 12:35 AM
Need fitting to tee into heater hose for temp sender Jeep Daddy Jeep CJ Forum 1 06-16-2003 10:45 PM
