Fuel return and vent line testing - JeepForum.com
post #1 of 3 Old 07-18-2010, 08:06 AM Thread Starter
EngChase
EngChase's Avatar
1980 CJ7
I know I have seen this somewhere on here, but I can't find it. Right now I have an MC2100 installed and I have a rich mixture I'm trying to solve. I have installed #46 jets and now the carb floods, to the extent that the bowl overflows. This didn't happen with #48 jets, only that the engine ran so rich that I am experiencing some washing of the cylinder walls. Now to the question. My fuel return line builds slight pressure when you blow into it. I doesn't when the gas cap is off. How does the vent line back to the charcoal canister work in conjunction with the fuel return line? Should both lines "breathe" freely? I have recently replaced the power valve. Thanks.
EngChase is online now
post #2 of 3 Old 07-18-2010, 09:30 AM
jeffyjensen
1980 CJ5
check your rear drivers side fender and inspect the rollover check valve and the vapor vent can that sits there. sounds like something is plugged
1980 CJ-5, Ford 351w, in restoration, kind of
jeffyjensen is offline
post #3 of 3 Old 07-18-2010, 11:52 AM
walkerhoundvm
1981 CJ8
let me help you with that:
http://www.jeepforum.com/forum/f8/ca...-help-1064615/
Went through the same problem. Sounds like jeffy is right - there may be an obstruction between the tank, the check valves, and the canister. My valve-canister line was plugged with charcoal when I tore down the system. That link will give you a pretty solid idea of how the whole fuel emissions/canister system is supposed to work.
-N
walkerhoundvm is offline
carb , cylinder walls , fuel system , gas cap , gasoline , jets , mc2100 , running rich , vent
Webber questions about fuel pressure regulator and fuel return line jatepper Jeep CJ Forum 26 01-19-2011 06:17 PM
Fuel Line Return for CJ5 kopperkid1 Jeep CJ Forum 5 06-11-2008 09:11 PM
Fuel return/vent hose. Where can I find one? 4XGore Jeep CJ Forum 3 06-28-2007 03:57 PM
CJ7 Fuel Return Line for TBI jfwireless Jeep CJ Forum 7 05-17-2007 09:37 PM
Fuel Return Line GarageCJ Jeep CJ Forum 3 12-14-2004 04:05 PM
