Fuel Pump Woes - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Fuel Pump Woes
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCount Down to KOH Sale!The Original 3/8" Ruffstuff Diff Cover!
Unread 11-08-2014, 01:41 AM   #1
cjjp
1974 CJ5
Fuel Pump Woes
NEW PROJECT:
Replace Fuel Pump
ISSUE:
40 dollar, electric fuel pump from auto zone that is graded for 4 cyl and 6 cyl was put on the jeep before I bought it.
It is leaking fuel
SOLUTION:
replace electric fuel pump with mechanical fuel pump
PURCHASED:
http://www.partsgeek.com/gbproducts/...FUUV7AodmEMAnw
PROBLEM:
The damn thing will not fit because the power steering does not grant enough room for the pump to slide into the engine block, and fit behind the power steering fluid reservoir.
THOUGHTS?
Now what....
cjjp is offline   Reply With Quote Quick reply to this message
Unread 11-08-2014, 05:13 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The power steering pump sounds to be in the wrong place hence the need for the electric pump. Normally the alternator is on that side of the engine granting lots of room for the pump.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
Unread 11-08-2014, 06:45 AM   #3
STJP
Street Jeep
STJP's Avatar
Pictures would be very helpful.
STJP is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 03:35 PM   #4
cjjp
1974 CJ5
Ok I took the power steering pump off and it appears I can fit it...
HOWEVER - I notice when sliding the mechanical pump in I have a hard time getting it to flush up against the block? Could this be due in part to the cam being in a position that is making it impossible to load the lever of the pump inside the block? If that is the problem how in the heck do I fix that?!?!
Thanks
JP
Unread 11-09-2014, 04:42 PM   #5
OldGyrene
Semper Fi
1978 CJ5
Thanks
JP
Just "bump" the starter, the cam will turn and it will slide right in: at least that is what worked on my install.
Jake
OldGyrene is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 04:43 PM   #6
Mike Romain
Yes that us how it works. You either use the bolts to pull the pump in or rotate the engine so the pump hits a lower spot on the cam.
Mike
Unread 11-09-2014, 09:34 PM   #7
82JeepCJ7
1982 CJ7
Also remember, there are two pumps used an AMC motors. One is facing upward, and the other faces downward.
Mine when I was building my motor...
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 10:03 PM   #8
dg6772
The part on the cam,called the eccentric,could also be worn. This is not uncommon. An electric pump may have been the solution at the time. Hopefully this is not the case,but be prepared.
Dave in Muskegon using Jf app
dg6772 is offline   Reply With Quote Quick reply to this message
