Fuel Pump Questions - JeepForum.com
post #1 of 6 Old 03-21-2013, 12:39 PM Thread Starter
CJ5Rookie
1981 CJ5
Fuel Pump Questions
I pulled my fuel tank this week and was pretty depressed with the condition of the interior. Lots of floaters, rust, and what looked like raw crude oil. The pump was covered in rusty shale and how fuel got through the filter cover is amazing by itself. Obviously the tank will need to be cleaned, Iíve never cleaned a fuel tank so Iím open to suggestions.
My old motor was the 151 Iron Duke. My new motor is a CPI V6 Vortec, a crate motor.
I assume I was going to have to replace the in tank pump assembly anyway due to the larger motor. Is that accurate, or can I use the original OEM replacement part? If I have to upgrade to a different pump what do you suggest?
CJ5Rookie is offline
post #2 of 6 Old 03-21-2013, 01:25 PM
CSP
The OEM pickup should be fine. You're going to need an electric pump capable of pushing the PSI that CPI needs. IIRC, that's somewhere in the 50-60psi range. The 151 pump was on the block and mechanically driven by an eccentric on the cam.
CSP is offline
post #3 of 6 Old 03-21-2013, 08:19 PM
cj5huntingrig
1974 CJ5
Replace the tank with an MTS poly tank. You'll thank me later.
Plus if you're going to the extent to do anything regarding the tank, replace the in tank pump. You kick yourself later if you don't.
E
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #4 of 6 Old 03-21-2013, 10:33 PM
reeper
1978 CJ5
I went with the MTS poly tank. prob will go down as the easiest repair on my jeep. Call MTS direct much cheaper than the dealers.
reeper is offline
post #5 of 6 Old 03-22-2013, 11:24 AM Thread Starter
CJ5Rookie
1981 CJ5
I'll look up the MTS Tank.
Thanks
post #6 of 6 Old 03-22-2013, 04:29 PM
BlueRubiconrich
steel fuel tanks suck!
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
