Fuel Pump Help.. - JeepForum.com
post #1 of 4 Old 08-10-2012, 09:28 AM Thread Starter
studer21
Fuel Pump Help..
Hi, I have been having issues ever since I purchased my CJ a couple years ago with my fuel pump. It is an electric fuel pump- Walbro I think. Anyway, it works fine all of the time unless I ever drive it at 3/4 to full throttle. The pump will stay on until I cut the jeep off. Whenever I try to restart after a scenario like that- most of the time the fuel pump doesn't cut on. I will sometimes wait an hour, or up to 5 days. Somehow, it will decide to work again and be fine until I give it 3/4 to full throttle. Really strange! I tried relieving the pressure thinking that was it for sure, nope. I have a feeling it may be voltage related or the fuel pump is just very finicky, possibly something wrong internally. I would love to get some feedback from somebody that has dealt with this or has a possible fix. Thank you guys
85 CJ. Golen Stroker. Always "In Progress"
studer21 is offline
post #2 of 4 Old 08-10-2012, 09:47 AM Thread Starter
studer21
I also have the MPI kit on- so it is fuel injected. Maybe the throttle position switch is malfunctioning? Just a thought I had, thanks guys
studer21 is offline
post #3 of 4 Old 08-10-2012, 11:37 AM
1SASjeepster
How much fuel pressure are you running? How much is your injection system supposed to have? That is necessary information to solve this problem. Have you put a voltmeter on the wires going to your fuel pump? Have you contacted the manufacturer about this issue? Maybe about what are the "electrical specs" for this particular fuel pump... If all else checks out, and the wiring is good and getting the proper volts/amps, change the fuel pump because it must be internal. But the manufacturer will be able to tell you if it is or not.
Did the jeep come with the MPI? I am assuming by what you wrote, no. Let me know.
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #4 of 4 Old 08-12-2012, 10:22 PM
BagusJeep
1981 CJ7
have you got a fuel pump relay? What is it doing during this episode?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
fuel pump
No fuel to fuel pump on stock 1946 CJ2A csmith28269 Jeep CJ Forum 12 09-29-2014 07:49 PM
1972 cj5 fuel pump to carb what size double flair from pump? chadco Jeep CJ Forum 4 04-18-2012 05:31 AM
Bad TBI electronic fuel pump or problem with fuel tank? boomvader Jeep CJ Forum 5 01-18-2010 10:26 PM
Fuel Pump - hard to pump by hand? tsujeeper Jeep CJ Forum 3 03-17-2009 03:08 PM
add elect. fuel pump; bypass old pump? Samoa CJ5 Jeep CJ Forum 9 07-12-2004 08:15 PM
