Fuel Pressure Regulator Weber - JeepForum.com
post #1 of 9 Old 04-04-2013, 07:50 PM Thread Starter
RDub69
1974 CJ5
Hi all. I recently installed a weber on my '74 CJ5 232 and a fuel pressure regulator from Mr. Gasket.
My question.... Is something needed to support the regulator? It seems rather heavy and I'm not too keen on the fuel line alone supporting it.
If something is needed for support what should I use?
If anyone has done this to their vehicle would you mind sharing some pics.
RDub69 is offline
post #2 of 9 Old 04-05-2013, 02:55 AM
BagusJeep
1981 CJ7
HAve you got pictures of your install?
Hose should not be subject to load and should preferably run in short straight lines. Tube should be held rigid with clips. If your regulator is not mounted it is going to stress the hose or tube.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 9 Old 04-05-2013, 04:17 AM
Joe73CJ5
1973 CJ5
I have read the Mr gasket brand of fuel regulator is junk and many people replace them with holley or weber brand. I have no experience with them, I use the weber brand.
Joe73CJ5 is offline
post #4 of 9 Old 04-05-2013, 06:38 AM
kjonesie
1983 CJ7
I agree with Joe, the Mr gasket regulator is garbage. I used the Holley. I made a bracket and mounted it to the top of my valve cover where the factory air cleaner went
kjonesie is offline
post #5 of 9 Old 04-05-2013, 06:48 AM
CJ Chet
This is what I used to support my Mr. Gasket regulator. (get a Holley).
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #6 of 9 Old 04-05-2013, 09:33 AM
BlueRubiconrich
I have a Weber on my 86 CJ7 I ran my fuel pressure regulater right off the carb with a brass fitting.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #7 of 9 Old 04-05-2013, 09:56 AM
ASteve
1972 CJ5
I know you have a different engine, but for what it's worth this is how I mounted mine. I made a small braket out of aluminum and attached it to my valve cover bolt.
The Mr. Gasket is not a very quality piece...Also, pressure guages filled with water do not read accurately when they get warm...
ASteve is offline
post #8 of 9 Old 04-05-2013, 06:07 PM
CJ Chet
FYI: Those gauges are not filled with water they are filled with mineral oil, and they are very accurate.
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #9 of 9 Old 04-05-2013, 08:00 PM
ASteve
1972 CJ5
ooops ... fluid .... hows that...
They are very accurate? I'm not too familiar with these gauges yet, but mine does change when it warms up, and Summit Racing states: http://www.summitracing.com/parts/rus-650310 Scroll down to Notes and it reads:
Notes:When reading fuel pressure, keep in mind that a fluid filled pressure gauge will change it’s reading as the temperature of the gauge case changes (Under hood temperature). Because it’s sealed to contain the liquid inside, a liquid filled gauge no longer compares line pressure to actual atmospheric pressure, reporting the difference. Instead, it compares line pressure to the pressure inside the gauge case. As the liquid in the case heats or cools, it expands and contracts, causing case pressure to change as much as 1 psi for every 30 degrees temperature change of the gauge. Will directly screw into any 1/8 NPT female port.
SC
ASteve is offline
