Hi all. I recently installed a weber on my '74 CJ5 232 and a fuel pressure regulator from Mr. Gasket.
My question.... Is something needed to support the regulator? It seems rather heavy and I'm not too keen on the fuel line alone supporting it.
If something is needed for support what should I use?
If anyone has done this to their vehicle would you mind sharing some pics.
Hose should not be subject to load and should preferably run in short straight lines. Tube should be held rigid with clips. If your regulator is not mounted it is going to stress the hose or tube.
I have read the Mr gasket brand of fuel regulator is junk and many people replace them with holley or weber brand. I have no experience with them, I use the weber brand.
I agree with Joe, the Mr gasket regulator is garbage. I used the Holley. I made a bracket and mounted it to the top of my valve cover where the factory air cleaner went
I know you have a different engine, but for what it's worth this is how I mounted mine. I made a small braket out of aluminum and attached it to my valve cover bolt.
The Mr. Gasket is not a very quality piece...Also, pressure guages filled with water do not read accurately when they get warm...
They are very accurate? I'm not too familiar with these gauges yet, but mine does change when it warms up, and Summit Racing states: http://www.summitracing.com/parts/rus-650310 Scroll down to Notes and it reads:
Notes:When reading fuel pressure, keep in mind that a fluid filled pressure gauge will change it's reading as the temperature of the gauge case changes (Under hood temperature). Because it's sealed to contain the liquid inside, a liquid filled gauge no longer compares line pressure to actual atmospheric pressure, reporting the difference. Instead, it compares line pressure to the pressure inside the gauge case. As the liquid in the case heats or cools, it expands and contracts, causing case pressure to change as much as 1 psi for every 30 degrees temperature change of the gauge. Will directly screw into any 1/8 NPT female port.
SC
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
