Fuel Pressure Regulation - JeepForum.com
post #1 of 10 Old 05-11-2013, 10:29 PM Thread Starter
Neuner-9R
I have an electric fuel pump and getting ready to go pick up a Holley fuel pressure regulator to get it to the 3-3.5 range. Can the pressure from the pump be regulated with a resistor or potentiometer in line with the positive terminal instead?
Neuner-9R is online now
post #2 of 10 Old 05-12-2013, 06:31 AM
Moparmandjh
1977 CJ7
How will that sense the fuel pressure as the demand changes?
A veteran is someone who, at one point in his life wrote a blank check Made payable to 'The United States of America' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in this country who no longer understand it.'
Moparmandjh is offline
post #3 of 10 Old 05-12-2013, 08:09 AM
swatson454
1983 CJ7
Weber? Here's a three-dollar regulator that works much better.
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #4 of 10 Old 05-12-2013, 09:04 AM
cj5huntingrig
1974 CJ5
No you cannot regulate the pump with resistance. You will burn it up or start a fire. I have the holley regulator and it works perfectly. You should buy an oil filled pressure gauge though. You can get a decent one from advance online for about $18. Contrary to popular advice on the forum, I had no luck with the bypass filter in the previous post even by following the exact directions posted. You also have the option of forgoing the regulator as long as you have the Holley red pump and change to a viton tipped needle and corresponding seat.
Tx. E
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #5 of 10 Old 05-12-2013, 09:47 AM Thread Starter
Neuner-9R
Tx. E
Thanks for the info.
Yeah, I tried that filter as well and it didn't work for me either. Glad to hear I'm not the only one. If it didn't cost more to ship than what it's worth, I give it to somebody.
post #6 of 10 Old 05-12-2013, 09:54 AM
swatson454
1983 CJ7
What pump are you guys running? I find your results interesting. The viton-tipped needle is stellar advice.
Shawn
post #7 of 10 Old 05-12-2013, 12:10 PM
cj5huntingrig
1974 CJ5
Holley Red
post #8 of 10 Old 05-12-2013, 01:32 PM Thread Starter
Neuner-9R
Shawn
From PO. Can't find name or model.
post #9 of 10 Old 05-18-2013, 05:50 PM Thread Starter
Neuner-9R
From what I've seen in research, the bypass filter regulates the pressure to 5psi however the weber likes 3-3.5 which may be why I didn't notice the difference. My pump puts out 7 psi. Just got the Holley regulator installed, set it to 3.5 and took it for a spin. Definitely an improvement!
post #10 of 10 Old 05-24-2013, 08:03 AM Thread Starter
Neuner-9R
Update: Before the regulator I was averaging around 15mpg but afterwards, with the same driving conditions, I'm now averaging 17mpg.
Never saw the improvement with the bypass filter.
