-   -   Fuel Pressure Regulation (http://www.jeepforum.com/forum/f8/fuel-pressure-regulation-1522191/)
Neuner-9R 05-11-2013 10:29 PM
I have an electric fuel pump and getting ready to go pick up a Holley fuel pressure regulator to get it to the 3-3.5 range. Can the pressure from the pump be regulated with a resistor or potentiometer in line with the positive terminal instead?
Moparmandjh 05-12-2013 06:31 AM
How will that sense the fuel pressure as the demand changes?
swatson454 05-12-2013 08:09 AM
Weber? Here's a three-dollar regulator that works much better.;)
http://i619.photobucket.com/albums/t...fuelfilter.jpg
cj5huntingrig 05-12-2013 09:04 AM
No you cannot regulate the pump with resistance. You will burn it up or start a fire. I have the holley regulator and it works perfectly. You should buy an oil filled pressure gauge though. You can get a decent one from advance online for about $18. Contrary to popular advice on the forum, I had no luck with the bypass filter in the previous post even by following the exact directions posted. You also have the option of forgoing the regulator as long as you have the Holley red pump and change to a viton tipped needle and corresponding seat.
Tx. E
Neuner-9R 05-12-2013 09:47 AM
Tx. E
Thanks for the info.
Yeah, I tried that filter as well and it didn't work for me either. Glad to hear I'm not the only one. If it didn't cost more to ship than what it's worth, I give it to somebody.
swatson454 05-12-2013 09:54 AM
What pump are you guys running? I find your results interesting. The viton-tipped needle is stellar advice.
Shawn
cj5huntingrig 05-12-2013 12:10 PM
Holley Red
Neuner-9R 05-12-2013 01:32 PM
Shawn
From PO. Can't find name or model.
Neuner-9R 05-18-2013 05:50 PM
From what I've seen in research, the bypass filter regulates the pressure to 5psi however the weber likes 3-3.5 which may be why I didn't notice the difference. My pump puts out 7 psi. Just got the Holley regulator installed, set it to 3.5 and took it for a spin. Definitely an improvement!
Neuner-9R 05-24-2013 08:03 AM
Update: Before the regulator I was averaging around 15mpg but afterwards, with the same driving conditions, I'm now averaging 17mpg.
Never saw the improvement with the bypass filter.
The time now is 03:49 PM.
