Fuel pressure?? - JeepForum.com
post #1 of 5 Old 09-08-2011, 12:48 PM Thread Starter
bamasteeler
Fuel pressure??
ON way to work today jeep started idling really rough and engine even shut down on me at stop lights a couple times. It acts like it's starving of fuel. Put an inline pressure gauge and when engine is running at idle it basically reads zero. What is fuel pressure of mechanical fuel pump? It seems to accelerate fine when reving the engine but stumbles hard when comes back to idle.
1980 Jeep CJ7
AMC 258, T176, D300,
AMC 20 REAR, D30 FRONT
1999 XJ CLASSIC
RC 3" front AAL rear
bamasteeler is offline
post #2 of 5 Old 09-08-2011, 04:19 PM
h2ogun
Mechanical pump output should be 4-8 PSI, normal around 6PSI.
h2ogun is offline
post #3 of 5 Old 09-08-2011, 04:28 PM Thread Starter
bamasteeler
Thanks for info
Ended up I put the wrench to intake manifold bolts, wouldn't call them loose but did get a little turn out of them. Started up and idling fine now.
1980 Jeep CJ7
1999 XJ CLASSIC
post #4 of 5 Old 09-08-2011, 08:52 PM
BagusJeep
1981 CJ7
A vaccuum leak can indeed lean it out.
The pressure at idle is an interesting one, where and how you measure it is important as a properly configured Jeep system relieves some of the pressure before it reaches the carb inlet, therefore the gauge may read low at idle if plugged in at the carb end of the fuel line
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 5 Old 09-08-2011, 09:03 PM Thread Starter
bamasteeler
I was tapped in just before the inlet to fuel filter
1980 Jeep CJ7
1999 XJ CLASSIC
