Fuel Lines for CJ8 w/304 - JeepForum.com
 1Likes
  • 1 Post By Mickey_Mouse
post #1 of 10 Old 10-19-2012, 11:03 AM Thread Starter
JeepGuy66
1976 J-Series Truck
Just picked up an 83 CJ8 project. Great body and frame. Came with a 304 and 5 speed. Needs complete fuel lines, brake lines and exhaust just to get going and see what I really have.
First time poster. First question.
fuel pump on the 304 is on driver's side. My understanding is fuel pump on the 258 is on the passenger side. Can anyone tell me if the fuel pump on the 4cyl is on drivers or passenger side?
Trying to figure out which fuel line set to purchase since there is no option for CJ8 with 304. Hoping that fuel pump on the 4cyl is driver's so I can just purchase that set since I know the 258 set goes to the wrong side. Any thoughts other than bending my own? Thanks much!
JeepGuy66 is offline
post #2 of 10 Old 10-19-2012, 11:11 AM
82JeepCJ7
1982 CJ7
When I swapped out my 258 for a 304, I made my own fuel line. It was much simpler than trying to piece together already made parts. Measure from the fuel tank, across to the drivers side frame rail, up the rail to the motor. Add a foot or so to that measurement. Go down to a hydraulic hose shop and get some stainless steel line. Have them cut it to your length. Stop at a hardware store and get a tubing bender and cutter (both are inexpensive and great tools to have in the future.) Then simply bend and fit your new line to your Jeep. Pick up some insulated clamps to fasten the line to your frame and your done.
If you need to make a pattern for a tricky bend, use a straitened out coat hanger to make a template. It will save you some time bending the tube.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 10 Old 10-19-2012, 11:32 AM Thread Starter
JeepGuy66
1976 J-Series Truck
Thanks for the quick reply.
I was hoping there would be a pre-bent option that would be a slam dunk but if not I'm not opposed to running my own. I assume it would be cheaper in terms of cash but perhaps not time; but that's OK. BTW. what are you getting for MPG on your 304?
post #4 of 10 Old 10-19-2012, 12:10 PM
82JeepCJ7
1982 CJ7
Zero right now... LOL.. Its not on the road yet.
post #5 of 10 Old 10-20-2012, 06:15 PM
Jbwardfamily
1978 CJ5
You can also use high pressure rubber fuel line. The pressures are not too high anyway and you wouldn't have to worry about bending anything. Just clamp and secure every 2 ft or so.
Jbwardfamily is offline
post #6 of 10 Old 10-21-2012, 10:53 AM Thread Starter
JeepGuy66
1976 J-Series Truck
I had read in a number of other posts that running hose under the cab was not recommended. Any other opinions?
Also, in regards to my original question, is it safe to say that the fuel pump on 4cycl is on the passenger side?
Thanks!
post #7 of 10 Old 10-21-2012, 03:17 PM
Mickey_Mouse
2013 KK Liberty
Mickey_Mouse is offline
post #8 of 10 Old 10-21-2012, 03:58 PM Thread Starter
JeepGuy66
1976 J-Series Truck
Thanks. I thought about using the first item you listed (fuel pump to gas tank for 304) but figured it would be too short?
post #9 of 10 Old 10-21-2012, 07:17 PM
Mickey_Mouse
2013 KK Liberty
Archie B likes this.
post #10 of 10 Old 10-26-2012, 02:44 PM Thread Starter
JeepGuy66
1976 J-Series Truck
Thanks all for the input.
I had something interesting happen in the last couple days. Found a guy on craigslist that was listing a rusted out CJ8 rolling chassis. It still had the brake lines and fuel lines attached. So I offered him 20 bucks if I could come snap a bunch of photos and he agreed. I immediately noticed that both the brake and the fuels lines ran along the drivers side and all appeared original. So immediately figured I could just use a pre bent kit and I could easily attach to the fuel pump. After a few minutes, one of the mechanics came out to chat. Really nice guy. I asked him about the fuel lines and he said he has seen them on both sides. He said something about V8 runs on one side and 258 runs on the other but of course scramblers weren't offered in a V8 so go figure. So I was thinking maybe this wasn't really a scrambler. Maybe it was a Wagoneer since I believe they use the same frame? He took me for a quick tour and I saw a number of rebuilds in the garage w/fuel line running passenger side. Not sure what to make of it but now having the pics of the lines running drivers side I am ready to bend my own once confirmed that pre bents are passenger side. Thanks much!
cj , fuel lines
