Fuel lines - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Fuel lines
New wheels at Jeephut.comRancho's 60th anniversary Spring rebate!Free shipping on Rugged Ridge XHD bumpers
Unread 02-21-2015, 01:47 PM   #1
Wile-e82
Fuel lines
Ok I am wanting to replace my fuel line from my tank to the fuel pump because it is rusted so I started looking them up and I found a pre bent line that will just mount right up along the frame and then I found a could buy a 20 stainless steel coil for half the price and I wondering if I got the coil could I bent it along the frame or would it crimp it to bad or would it be better to just spend the extra money and get the pre made fuel line? I'm new to all of this so sorry if it is a stupid question.
Wile-e82 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2015, 02:05 PM   #2
Jim1611
Jim1611's Avatar
Sure you can make your own fuel line out of the coil material. Just remember not to make any sharp bends and it won't collapse. This stuff is used all the time.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2015, 02:42 PM   #3
HackFabrication
1976 CJ5
It really helps if you fill out your profile, or at least included what year/model of Jeep you are posting a question about....
Stainless steel line is a bugger to bend correctly. I had hopes of going hard lines on my project. Even bought a coil of copper tubing to use as a pattern:
Bought the SS line from Summit, tried to bend it, and it was a disaster.
If you have a stock CJ, go with pre-bent lines from inlinetube.com :http://inlinetube.com/Preformed%20Li.../JP-CAT-03.htm You can get them in regular steel or stainless.
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote Quick reply to this message
Unread 02-21-2015, 02:57 PM   #4
Wile-e82
Yeah that's what I have a stock 1982 cj7
Unread 02-21-2015, 10:52 PM   #5
commadore64
commadore64's Avatar
1980 CJ5
If you can find a pre-bent kit that suits your needs... do that! I've got a non-stock engine in my CJ and bent up some ss fuel line. That was a major job to say the least. SS is hard to bend and work with.
1980 CJ-5
My build thread: http://www.jeepforum.com/forum/f8/bo...j-5-a-1290405/
"For evil to flourish, all that is needed is for good people to do nothing."
commadore64 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2015, 11:28 PM   #6
82JeepCJ7
1982 CJ7
Looks like a good excuse to buy a quality tubing bender. I made mine from a coil of line as well. Had a good quality bender and it went fine.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 02-22-2015, 12:01 AM   #7
Cutlass327
Cutlass327's Avatar
1978 CJ5
I used one of these benders to bend mine. I bought the line thru 4wd.com, bulk S.S. line 3/8 and 5/16.
Here's how it came out:
I found a quick squirt of WD40 or other lube helped bend the line, as the one lever has to slide along the line to make the bend.
Rick
1978 CJ5 258/T177/D300, '86 D30/D44 WT axles, 'glass tub windshield frame, and fenders, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote Quick reply to this message
Unread 02-22-2015, 12:09 AM   #8
commadore64
1980 CJ5
I could not get that type to bend my tubing (1/2")... had to get one of these:
1980 CJ-5
Unread 02-22-2015, 09:10 AM   #9
Cutlass327
Cutlass327's Avatar
1978 CJ5
You used 1/2" for fuel lines?? Running a supercharged Chevy 502?
Rick
Unread 02-22-2015, 10:05 PM   #10
WolfcreekCJ
1977 CJ7
Had a nearly impossible time trying to fit pre bent ss lines into my 77 cj7 with the body on. ultimately had to cut and splice. that sucked. If I had it to do again I would just use regular steel tubing. bends easy, cheap, the old lines lasted 35 years. Just try to take out the old lines in one piece, it will give you an idea of what your up against.
All it takes is time and money
WolfcreekCJ is offline   Reply With Quote Quick reply to this message
Unread 02-23-2015, 07:30 AM   #11
HackFabrication
1976 CJ5
That is so true. Stainless is pretty. But has it's drawbacks.
Unread 02-23-2015, 07:34 AM   #12
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I put stainless brake lines in in 2009 and got that plastic lined gas line from Napa so ethanol wouldn't rot it out. My gas lines have failed from rust and must be replaced but my brake lines still look new.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
Unread 02-23-2015, 07:48 AM   #13
MountainHound
MountainHound's Avatar
1979 CJ7
I used Poly-Armour recently to replace my hard lines. Bought it through autozone. Easy to bend and flare. I also bought some sprial armor to protect it and slid it over. Price is around a dollar a foot so cheap if you make a mistake.
Just have it on for a couple of months so not sure how well the Poly-Armour stands up yet.
1979 CJ7
2011 WK2
MountainHound is offline   Reply With Quote Quick reply to this message
Unread 02-23-2015, 07:55 AM   #14
rixcj
rixcj's Avatar
1979 CJ5
Another challenge when making your own stainless steel lines, is flaring it. You need a real good flaring tool.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 02-23-2015, 07:57 AM   #15
grapehead
1977 CJ7
i used aluminum tubing. bends easy and doesn't rust.
grapehead is offline   Reply With Quote Quick reply to this message
