fuel line routing pump to carb? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > fuel line routing pump to carb?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSuper Low Prices on TJ Bumpers and $399.95 Tire Carriers!Genright at JeepHut
Unread 05-12-2008, 12:00 PM   #1
BioTex
OIIIIO
BioTex's Avatar
I'm noticing on my 85 258, that the metal line that bends around the front of the valve cover, wedges next to the radiator/heater hoses. These must be tranferring a lot of heat into the fuel. Also the filter is really close to the #1 exhaust manifold port. I don't think this needs my attention, and was wanting to see a picture from someone that has a stock set up so I can rework to match.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
1986 CJ10-A SD-33 Diesel/727/np208
1971 800B with 345/T-19
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
YJ Buggy Build Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline   Reply With Quote
