Fuel line question; need to know the size of the feed and return - JeepForum.com
post #1 of 8 Old 07-11-2010, 03:59 PM Thread Starter
somdfisher
1981 CJ7
Just need to know the size of the feed and return. 81 7 with 258. Thanks much.
O|||||O 1981 CJ7, 258, 4 speed..If it ain't cut, it ain't custom.
somdfisher is offline
post #2 of 8 Old 07-11-2010, 06:26 PM
h2ojeep
1978 CJ7
The feed line is 5/16 ID coming out of the tank and also 5/16ID on the fuel pump, but the line in between is 3/8ID. The return line is 1/4ID at the tank and the line coming from the return on the filter is 5/16ID.
h2ojeep is offline
post #3 of 8 Old 07-11-2010, 08:18 PM
Coiz
1979 CJ7
My 1979 had 5/16" line feed from the tank to the engine on the passenger's side frame rail and 1/4" return line from the carb to the tank on the driver's side frame rail. The fuel vapor line up to the canister is also 5/16" and runs up the driver's side frame rail.
Mike
Coiz is offline
post #4 of 8 Old 07-11-2010, 08:24 PM
248107
1983 CJ7
You might check but if you decide to go electric fuel pump someday return line should be 5/16.Might save you some trouble later on.
Mike
248107 is offline
post #5 of 8 Old 07-12-2010, 11:01 PM
h2ojeep
1978 CJ7
MY BAD
I have posted something that is NOT correct.
The line size are outside diameter, OD and NOT ID.
The feed line is 5/16 OD coming out of the tank and also 5/16 OD on the fuel pump, but the line in between is 3/8OD. The return line is 1/4OD at the tank and the line coming from the return on the filter is 5/16OD.
My apology.
h2ojeep is offline
post #6 of 8 Old 07-13-2010, 05:57 AM Thread Starter
somdfisher
1981 CJ7
It's all good, I appreciate the replies. If I went with 5/16 all around would I still be good?
post #7 of 8 Old 07-13-2010, 06:40 AM
Coiz
1979 CJ7
Yes, 5/16" feed and return would be perfectly fine and actually preferred if you ever decided to switch to a fuel injection system.
Mike
Coiz is offline
post #8 of 8 Old 07-13-2010, 06:42 AM Thread Starter
somdfisher
1981 CJ7
Sweet, I'm picking up 25 foot of it today so I wanted to be sure. Thanks a lot.
Webber questions about fuel pressure regulator and fuel return line jatepper Jeep CJ Forum 26 01-19-2011 06:17 PM
Fuel Return Line specwarCJ Jeep CJ Forum 11 03-24-2010 08:45 PM
Which line is transmission line feed and return on radiator? sweet76 Jeep CJ Forum 4 01-01-2010 08:45 AM
Is a fuel return line necessary??? NWA_CJ7 Jeep CJ Forum 2 07-13-2009 02:13 PM
fuel return line???? petey156 Jeep CJ Forum 4 11-24-2007 03:10 PM
