Fuel Line Question - JeepForum.com
post #1 of 8 Old 03-20-2002, 02:03 PM Thread Starter
TG CJ7
Post Fuel Line Question
Ive got two questions reguarding my brothers 84 CJ7.
We just put the gas tank and new gas lines on last weekend. I wasnt sure which lines went where so I had to make some educated guesses, but Im not sure if its right or not. There are two lines comming out of the sending unit, one goes to the fuel pump on the passengers side, i think the other goes to the charcoal canister on the drivers side. I ran the gas tank vent line up to the fuel filter. Does that sound right to everybody.
1979 CJ7 Renegade 304, 3spd, 2.5 BDS lift, Hedman headers.
Check it out
TG CJ7 is offline
post #2 of 8 Old 03-20-2002, 08:45 PM
Cm481ems
Post
I had some trouble with this same thing, it is not easy... two lines come from tank, one that is bigger goes to fuel filter then to fuel pump - up to carb.. hard line comes from carb down driver side of engine and goes all the back to rollover check-valve(in corner space behind rear tire) then to return port on tank... check this site out it might help if I haven't.. CM JEEP ADVENTURES UNDER THE HOOD
84 CJ7, frame up restoration. Body off an 80. 1"body lift, 2 1/2 suspention lift, and 1" shackles. 33X12.5X15 BFG's one piece moser axles in rear with 4.10's and ARB locker front and rear..
Cm481ems is offline
post #3 of 8 Old 03-20-2002, 10:13 PM Thread Starter
TG CJ7
Post
That is a Great site. I think Ive seen it before but never really looked at it. Thanks.
On a side note, since I have new lines these have to be primed. What is the best way of doing that? I was just turning the motor over. Will that do the job if I do it long enough??
Thanks agian
Check it out
TG CJ7 is offline
post #4 of 8 Old 03-20-2002, 10:15 PM Thread Starter
TG CJ7
Post
Thanks agian
Check it out
TG CJ7 is offline
post #5 of 8 Old 03-20-2002, 11:52 PM
1911shtr
Post
Hey im in KC with a 79 CJ7 with a 304. Frame up in 98 new fiberglass everthing and hard top. new 31" tires on Alloy wheels. New rough country lift being installed. Warn locking hubs. New seats
1911shtr is offline
post #6 of 8 Old 03-21-2002, 01:25 PM
junger
Post
What site?
junger is offline
post #7 of 8 Old 03-21-2002, 05:24 PM Thread Starter
TG CJ7
Post
http://4wheeldrive.about.com/cs/jeepmaintenance/
Check it out
TG CJ7 is offline
post #8 of 8 Old 04-17-2002, 05:12 AM
rick_the_jeepman
Post
TG CJ7,
Yes just turning over the engine will prime the lines, I have just done the same thing "Replacing all fuel lines".
rick_the_jeepman is offline
Fuel line question? Area.3.Fiftyone Jeep CJ Forum 4 11-18-2009 10:32 AM
Fuel line question CompGuru Jeep CJ Forum 70 01-28-2008 09:01 PM
Dumb Brake Line and Fuel Line Question GroundUpCJ7 Jeep CJ Forum 3 04-02-2007 07:01 PM
Fuel line question(different than below). TheJunkMan2005 Jeep CJ Forum 2 05-27-2005 07:27 AM
CJ Fuel Line Question longlimb Jeep CJ Forum 8 05-26-2005 10:57 AM
