Fuel line question - JeepForum.com
post #1 of 4 Old 02-03-2012, 12:32 AM Thread Starter
dan-cj7
Fuel line question
I'm building a CJ7 up with stroker and I am using a 93 YJ as a donor. I'm thinking of using the fuel lines from the YJ. My question is, should I be concerned about the fuel supply running down the same side (left frame rail) as the exhaust? Am I worried about nothing or will I have problems with vapour lock or effiency problems?
Thanks for your advice.
Dan
1984 CJ7 - Under construction
4.6L stroker with MPI & AX15 with D300
OME 2.5" YJ springs
http://www.jeepforum.com/forum/f8/dans-downunder-84-cj7-build-1299387/
dan-cj7 is offline
post #2 of 4 Old 02-03-2012, 12:54 AM
Fins
1980 CJ7
I would say route them down the passenger side all the way to the radiator across the front then down the drivers side. Just my opinion.
My CJ suffers from vapor lock because my fuel lines & filter are near the exhaust pipes. I'm hoping to fix it soon.
Fins is offline
post #3 of 4 Old 02-03-2012, 12:56 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
could use a heat shield? mine is ok next to my exhaust, but mine is a few inches from the frame
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #4 of 4 Old 02-03-2012, 01:04 AM
Fins
1980 CJ7
I have Thermo Tec express sleeves on the fuel line where it comes across from the passenger side over the transmission. And another one as it runs along the manifold up to the front of the fuel rail. I'd really like to run a whole new line as I described in my other post.
What I haven't insulated yet are the fuel line, filter and pump that are in front of the gas tank next to the exhaust.
Fins is offline
Fuel Line Question 75 CJ-5 304 AJ075 Jeep CJ Forum 2 06-24-2011 08:09 PM
Fuel line question? Area.3.Fiftyone Jeep CJ Forum 4 11-18-2009 10:32 AM
Fuel line question CompGuru Jeep CJ Forum 70 01-28-2008 09:01 PM
Dumb Brake Line and Fuel Line Question GroundUpCJ7 Jeep CJ Forum 3 04-02-2007 07:01 PM
Fuel Line Question TG CJ7 Jeep CJ Forum 7 04-17-2002 05:12 AM
