Quantcast Fuel Line to Gas Tank Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Fuel Line to Gas Tank Questions
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 07-15-2006, 10:08 PM   #1
ishcak
Ok, I have a new 15 gallon tank purchased from 4wd (85 CJ7). The tank with the sender unit, has a total of six nipples to connect fuel lines to. Obviously I have eliminated the two filler nipples that connect to my gas filler (where you would put in fuel).
I have concluded that the bigger nipple on the fuel sending unit has a hose that goes to my fuel pump. Now I am left with my small nipple on my sender unit and two same size nipples that come out of the side of the tank. Where do all these go to.
I only have two fuel lines left under my car and three nipples. The old tank I took out (original) did not have two nipples on the side.
PLEASE HELP with any pictures, neccessary fuel line sizes, etc.
ishcak is offline   Reply With Quote
Old 07-15-2006, 11:40 PM   #2
tmak504
1976 CJ7
haha sorry im just giggling at how many times you said nipple and my small nipple..I don't have anything good to add to this post aside from can you just plug those?
[url]http://memimage.cardomain.net/member_images/4/web/2236000-2236999/2236506_1_full.jpg[/url]
tmak504 is offline   Reply With Quote
Old 07-16-2006, 12:27 AM   #3
fuzz401
1978 CJ7
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
http://img2.photobucket.com/albums/v11/fuzz401/?action=view&slideshow=true
http://photobucket.com/albums/v31/fuzzcj7/?action=view&slideshow=true
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline   Reply With Quote
Old 07-16-2006, 01:36 AM   #4
ishcak
That's a good start. Any info on the size of lines. Anything else anyone. I want to be prepared . This site is the bomb if you utilize all of you JEEP GENIUSES
Old 07-16-2006, 02:30 AM   #5
junglejeep
Not me that about sums it up.
I want a CJ-6 with a hardtop.
junglejeep is offline   Reply With Quote
Old 07-16-2006, 09:44 AM   #6
John Strenk
What was I thinking
1976 CJ5
Cut the old hoses off by slitting the hose with a razor. This prevents breaking a nipple off some of those impossible to buy parts on the vent system.
John Strenk is offline   Reply With Quote
Old 07-16-2006, 07:17 PM   #7
ishcak
SEE DIAGRAM ABOVE
Okay, SO I swapped my two fuel lines to the fuel pump. But still have no where to put the lines that come off the side of the tank.
Where is my liquid check valve located? I only have one hose remaining in my old system. It was hooked into my new tank but runs to the engine compartment where it is not connected to anything.
I guess most importantly where is my liquid check valve and is it possible for me not to have one. If so what do I do with the remaining to nipples off the side of my tank.
Old 07-17-2006, 03:27 AM   #8
77cjheepy
look behind the left side, rear. were your taillight mounts.i believe all of it is behind the panel.mine is encrusted with rust and dirt.
77cjheepy is offline   Reply With Quote
Old 07-17-2006, 08:26 AM   #9
Aphelion79
Yeah the liquid check valve is right up inside the drivers side rear corner... encrusted with nasties
1982 CJ7
Iron Duke "Hurricane" 151 CID 2.5L 4-Cyl
T177 Tranny | Dana 300 T-Case
Dana 30 Front | AMC 20 Rear
Aphelion79 is offline   Reply With Quote
Glock Forum
