fuel injection kit - JeepForum.com
post #1 of 5 Old 02-19-2008, 09:52 PM Thread Starter
KINGJRK1974CJ5
fuel injection kit
im looking to go fuel injection conversion kit for my 258 4.2l inline 6 any ideas on if i should or got with a 4brrl carb
KINGJRK1974CJ5 is offline
post #2 of 5 Old 02-19-2008, 10:02 PM
bdmonist
WTF is that?
bdmonist's Avatar
I have this system installed on my 350, Junkyard option, very detailed instructions, almost idiot proof - Much cheaper than off the shelf systems. You can use it on your 258 as well.
http://www.binderbulletin.org/forums...ad.php?t=47254
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #3 of 5 Old 02-19-2008, 11:53 PM
bjf498
bjf498's Avatar
1983 CJ7
also look at affordable fuel injection for an easy option.
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline
post #4 of 5 Old 02-20-2008, 11:27 AM
jlynch
I also have the same junkyard setup. Just keep in mind that if you go that route you will have to program a chip tp match your setup.
92 Jeep wrangler/ Chevy 350/ sm465/ 205/ Dana 60/ Dana 70/ 4.56 gears/ detroit locker/
jlynch is offline
post #5 of 5 Old 02-20-2008, 11:34 AM
USMCredneck
1979 CJ5
file:///C:/Documents%20and%20Settings/Owner/Desktop/junkyardtbi.asp.htm
This is the junkyard setup I will be going with when I do my FI. It didnt mention needing a new chip but I know absolutely nothing about fuel injection, so check with some of the other folks on here about that.
Semper Fi
79 CJ5. 258, T-18A, D20. 33s
08 Dodge Ram 3500 DRW DD/tow rig
USMCredneck is offline
CJ Fuel Injection? smitty586 Jeep CJ Forum 32 03-17-2014 01:12 AM
Fuel Sending Unit and Fuel Injection Question CJman77 Jeep CJ Forum 4 12-21-2009 06:01 PM
Fuel Injection lycowarrior Jeep CJ Forum 3 09-17-2005 11:34 AM
fuel injection on 258 supersly_jones Jeep CJ Forum 2 07-27-2004 10:09 AM
258 Fuel Injection? skirider Jeep CJ Forum 15 11-10-2002 11:57 PM
